964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
DAVIDGT996
PostPosted: Thu Mar 14, 2019 5:15 pm    Post subject: Found this under the Fuel Filler Cap- What is it for? Reply with quote
Not quite sure what the item is supposed to do as it just sits there not attached to anything.
2001 C2 Coupe Tip
Black, GT3 kit, lowered
 Filesize:  45.05 KB
 Viewed:  763 Time(s)
cvega
PostPosted: Thu Mar 14, 2019 5:24 pm    Post subject: Reply with quote
some trickle charger connector maybe??
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
moorhouse
PostPosted: Thu Mar 14, 2019 5:25 pm    Post subject: Reply with quote
Has someone routed the cables for external battery charger through to the fuel flap area. Looks to me like a quick fit extension cable similar to those with the Ctek etc so you don't have to use the crocodile clips every time.. Actually a really good place to put it assuming thee is no spark risk when connecting or disconnecting.
Cheers......Ian
40th Year Anniversary #698
PostPosted: Thu Mar 14, 2019 6:57 pm    Post subject: Reply with quote
Well its not standard thats for sure !
Wire colour would indicate its for a trickle charger ..
Im not sure thats the best place to put an electrical connection that might possibly spark at some point Surprised
Chris_in_the_UK
Estoril
PostPosted: Thu Mar 14, 2019 9:23 pm    Post subject: Reply with quote
Looks like a charger connector?
2006 Cayman S PCCB's
Dammit
Watkins Glen
PostPosted: Fri Mar 15, 2019 7:55 am    Post subject: Reply with quote
My uncle (RAF fast jet pilot and later BA Captain) once put his cigarette out in a jar of petrol in front of me to show that it was the vapour that catches fire.
I’d still never do the same thing- my tolerance for risk is lower than his, even perceived risk. As such, I’d have that connector and associated wiring out of there.
DAVIDGT996
PostPosted: Fri Mar 15, 2019 2:18 pm    Post subject: CTEK Trickle Charger Reply with quote
Ok Thanks - so I could get a CTEK spark free charger and use that to charge the battery via the petrol filler cap.
I have another weird connection cable end under the bonnet which I have no idea what is for - will post a photo up of that one shortly.
2001 C2 Coupe Tip
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Mar 15, 2019 2:21 pm    Post subject: Reply with quote
Sounds like the sort of uncle every lad should have Cool
PostPosted: Fri Mar 15, 2019 2:22 pm    Post subject: Re: CTEK Trickle Charger Reply with quote
Please use a torch...and not a candle Grin
Robertb
PostPosted: Fri Mar 15, 2019 2:27 pm    Post subject: Re: CTEK Trickle Charger Reply with quote
There would presumably need to be terminals attached to the battery.
I would want any mystery cables tested before connecting anything to them.
Maybe you've got an early 996 plug-in hybrid prototype? Dont know
DAVIDGT996
PostPosted: Fri Mar 15, 2019 5:50 pm    Post subject: Mystery Tour Reply with quote
I will follow the cables through and see where they end up. How exciting
2001 C2 Coupe Tip
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Mar 15, 2019 8:53 pm    Post subject: Reply with quote
Agreed - look like ctek charger connection.
Hard to see why you'd route it there rather than up from battery to near the wipers - remote from any petrol vapour....
918s had some well documented fires attributed to petrol filler & exhaust proximity.
