964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Mar 12, 2019 12:13 pm    Post subject: Anyone got a suspension kit for a 996 C2? Reply with quote
Anything considered, standard, m030, koni etc.
Just springs / shocks or complete struts.
Pairs or all 4.
Must be low mileage take offs.
Cheers.
Pecky
PostPosted: Thu Mar 14, 2019 9:49 am    Post subject: Reply with quote
Just put on mo30 kit from porshe £1600 sturs springs top mounts bump stops and anti roll bar,not sure id want to fit pre owned,mine had sone 85k and all corners showed signs of wear
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Mar 14, 2019 10:02 am    Post subject: Reply with quote
I have a full set of GT3 units, zero miles since rebuild, with a full set of brand new Tarett top mounts.
Gooey36
PostPosted: Thu Mar 14, 2019 12:22 pm    Post subject: Re: Anyone got a suspension kit for a 996 C2? Reply with quote
Pairs or all 4.
Cheers.
I’ll be removing my standard setup from my 2003 C2 with 77k on the clock within the next month including links, ARB’s and top mounts if that’s roughly what you’re after?
Current: 2003 996.2 C2
Daily: 2016 Audi A4 Avant S-Line TDi
NedHan79
PostPosted: Thu Mar 14, 2019 10:33 pm    Post subject: Reply with quote
I have m030 springs that I’ve just pulled out to fit spax lowering springs. I might let them go but I’d need some time to run on the new stuff to make sure I’m ok.
If you don’t get anything anytime soon give me a shout and I’ll see how I’m getting on
wasz
PostPosted: Fri Mar 15, 2019 6:33 pm    Post subject: Reply with quote
Hi thanks all for the offers!
I've just sorted some 10k mile M030 springs.
I will probably pair them with new koni special active dampers unless anyone has some really low mile dampers on the shelf.
NedHan79
PostPosted: Fri Mar 15, 2019 7:15 pm    Post subject: Reply with quote
Good hit on the springs. I found them hard enough tbh. I never had the standard suspension so can’t compare it to the m030 but they’d be plenty hard enough. I just pulld mine out to fit lowering springs
asterix_the_gaul
PostPosted: Fri Mar 15, 2019 8:03 pm    Post subject: Reply with quote
You won't be disappointed with the Koni special active shocks.
I think the cheapest was carnewal, email Gert for a quote with shipping to the UK
Front Top mounts I got from autodoc, leave enough time for delivery
