991 : 2011- 19
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Basalt911
PostPosted: Wed Mar 13, 2019 12:31 pm    Post subject: Reply with quote
absolutely, recommend a check - a no-brainer
my point is that some light scoring is presumably acceptable on a 98k engine and too many people just run away at the mere mention of the S word (hence 10/11 cars quote). Light scoring and then all the right measures to prevent further damage is presumably acceptable at that age?
I guess nobody bore-scopes 98k M3s or Astons, but I assume they'd find less than perfect pictures if they did? Or maybe I'm talking b0ll0x.
ragpicker
Reims
PostPosted: Wed Mar 13, 2019 12:51 pm    Post subject: Reply with quote
I don't know, I'm no expert, but if you were looking for a 997.1 and found mild scoring would you be happy - especially with the knowledge of the common failure?
My 986 boxster is on 160k miles (essentially same engine as the 997) , had the camera down the bores by my local indy - zero scoring marks.
My 996 turbo (different engine altogether) had a complete rebuild at 78k miles - no scoring whatsoever.. you could still see the cross-hatching on the cylinders from when they were manufactured.
10/11 sounds extreme and it probably is but this forum is littered with tales of people looking to buy who have walked away from many cars due to this. There's also a good few tales of engine failures unfortunately.
Its not just the M96/7 engines either. The V8's in my cayenne turbo are known to score! Incredible. nooo
996 turbo - FOR SALE, Price reduced: http://911uk.com/viewtopic.php?t=131025&highlight=
Rhodris-dad
2015 Porsche 991 Carrera 4 GTS
PostPosted: Wed Mar 13, 2019 2:10 pm    Post subject: Reply with quote
As "ragpicker" says...the engine has history....it is usually cylinders on bank 2 that score basically through overheating. This affects the coating on the pistons too. On some engines a light tap can be heard...which is piston slap.
The scoring is different to what you would expect..hence the need for someone with expert knowledge (not me Floor )
There are some good photos on the Hartech website
My 996 engine was rebuilt by Hartech and when I sold it, I held out for a premium price (which some people questioned)
As a coincidence, I posted a PM to the guy who bought it off me last weekend, he is a member of this forum.
After 5 years of ownership he has had no issues, which is testament to the guys at Hartech and to me for emptying my wallet. Floor
2015 991.1 C4GTS PDK
2010 997 C4S PDK sold
2003 996 C2 Tip sold
simkin911
PostPosted: Wed Mar 13, 2019 5:26 pm    Post subject: Reply with quote
As someone looking for a 997 - I’m grateful to the OP for starting this thread and all the subsequent contributors.
However, some of the opinions expressed herein leave me a little nervous. Added to that, there is a car (S model) I’ve found that I am interested in but the seller organised a health check as part of the sales process to help buyers. The bore scope check simply reads ‘clear’.
I’m not doubting this result (80k on car) but another thread on this site suggests the result is also influenced by the technician’s ability and light quality etc. Added to this, Hartech seem to suggest that a clear scope now doesn’t mean it’d be clear next year or the year after... etc.
I’m coming round to thinking I’m maybe simply better off considering a 997.1 c2 (with IMS upgraded) or aim for a 997.2 a little later down the line or a rebuild car. There was a GR 997 on Pistonheads last week for £8k requiring a rebuild but I’d prefer to buy and drive.
So, for the OP - yes, get a bore scope check but it seems it may only be as good as the technician and the result may only be 100% relevant at the time of purchase!
Starting to search for a 997 (maybe 996) after 15 years of F/E Porsches
resigner
PostPosted: Wed Mar 13, 2019 7:19 pm    Post subject: Reply with quote
Right.
Can you all stop running away from Bore Score cars?
As we have said, many times before, there are degrees of score. Light, expected, lots, bad. Just because a car has it, doesn't mean it is a problem. You need the Boroscope to be done by someone who actually know what they are doing. Get the pictures, ask the lovely people on here what they think (in private).
My car has 81k miles, was recently checked, and came up perfectly clean. I know there are people on here who have run cars with a little bit of scoring. I mean, it's an engine, every single engine in the world will show some scoring at some point, on any, of any make.
Get it checked (anyone know a good Indy in Devon? SCS? (arent they sofa's???))
98k miles isnt a problem, its all about if it's been looked after?
Now, back to bore score. Are the left hand tailpipes sooty? Does it smoke when running from that side only? These are the first things to check, because the bores are more susceptible on one side, which comes out the left hand side, so smoke, while running, for a period of time, from the left, probably bad bore scoring. BUT the only way to know for sure is to get it Boroscoped, which isn't expensive, cost me about £100 recently.
Don't get hung up on any one car, there are plenty out there, though sounds like you are at the low end of the budget scale. maybe look at a Cat D car? They are fine as long as they are repaired properly, and will be 30% cheaper.....
PM me if you want to chat, I went through the same thing 4 years ago!
a1butch
PostPosted: Thu Mar 14, 2019 5:14 pm    Post subject: Reply with quote
Hi, out of interest which car is this? Sounds suspiciously like mine!
simkin911
PostPosted: Thu Mar 14, 2019 5:37 pm    Post subject: Reply with quote
Not your car. Different colour, different country!
tvrkris
PostPosted: Fri Mar 15, 2019 12:42 pm    Post subject: Reply with quote
thank guys for all your posts.... I am now in that paranoid moment as there are lots of horror stories about the Gen 1... am I better paying more for a gen 2????
not really fancying a engine rebuild at 8k......
the guy had the car advertised for 20k I have seen the reciept for the engine change at bristol porsche was cared for by them until 2013 then by SCS porsche in Devon... from the pictures looks like it had a few stone chips at the front and was in silver heated seats, BOSE and reversing sensors.
i thnik he had it up from around begining of Feb and it is no longer advertised it is still for sale but the advert has finished I think.
checked MOT history nothing much to report on that
Front tyres wearing slightly on inner edges only not from MOT
passed every MOT from 2013 only failed in 08 and 13 on head lamp aim....
frustrated Dont know
PostPosted: Fri Mar 15, 2019 12:52 pm    Post subject: Reply with quote
If you're able to buy a Gen2 car I would.
It's a straight choice.
(a) Spend £30k now for a newer car and relative peace of mind.
(b) spend £20k now + a continuous nagging doubt + a possible £8k spend at some time.
Good luck Thumb
PostPosted: Fri Mar 15, 2019 1:03 pm    Post subject: Reply with quote
It’s a high mileage car. Which has a huge effect on resale values. Everyone buys a Porsche to keep, no one ever does! Very hard to sell on with those miles, chance of the dreaded borescore, personally I’d run a mile. Ok the engines done half the miles, everything else hasn’t. Think what the trade would be offering him for that car, and that’s closer to its retail value.
There’s plenty out there, it’s a buyers market, just wait for the right one (with the engine already Hartech or equalivalent rebuilt by someone else!) easypeasy.
Everyone will say condition condition, unless your keeping it forever- mileage mileage!
991 C2S PDK with X51 430 powerkit in racing yellow, PCCB, PDCC, PSE, Carrera S alloys, Sports design package with ducktail.
“Herman yellow, the last of the naturally aspirated”
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
Racing Yellow, there really is no substitute
tvrkris
PostPosted: Fri Mar 15, 2019 1:20 pm    Post subject: Reply with quote
Just put details into we buy any car....
They would offer £11680. can this be right??
what would a dealer be offering?
PostPosted: Fri Mar 15, 2019 1:26 pm    Post subject: Reply with quote
WBAC offer the minimum price they think they could get at auction less their likely costs.
A dealer might offer more if they felt it was a better car than that but I suspect with 98k miles showing they'd want it for under £13k.
tvrkris
PostPosted: Fri Mar 15, 2019 1:40 pm    Post subject: Reply with quote
I have just seen this
https://www.pistonheads.com/classifieds/used-cars/porsche/911-carrera-997/porsche-911-997-carrera-2/9515395
3.6 2005 with 108000 at Zuffenhaus £17995....
I will look to secure a Gen 2 I think...
Cannop
PostPosted: Fri Mar 15, 2019 2:08 pm    Post subject: Reply with quote
As the years go by mileage becomes less important, I'd go as far to say it becomes one of the least important aspects when buying a 997.1 as the youngest are 10+ years old now.
Of far more importance is the history of work carried out and by that I mean not just a stamp in the book every service interval as that's the bare minimum a car should receive.
Having receipts/history for non service work carried out on the engine, brakes, suspension, ancillaries, radiators, etc should be what you're looking for coupled with the general feel of the car, how well the interiors fared, the condition of the bodywork and paint and how many previous owners it's had, stuff like that.
Once a car gets near 100k or 10 years old then milage is pretty much irrelevant and the above points are what you should be taking into account, at 10 plus years if any of the above work hasn't been done it certainly will need doing in the near future even if the car's only done 50k.
I'd far rather buy a properly cared for and documented 997.1 with 100k+ on the clock than a 50k one with only the stamps in the service book.
Rhodris-dad
PostPosted: Fri Mar 15, 2019 2:28 pm    Post subject: Reply with quote
+1
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Mar 15, 2019 2:41 pm    Post subject: Reply with quote
@Rhodris Dad... with your car when you found it had scored bores, what led you to get the diagnosis done?
PostPosted: Fri Mar 15, 2019 2:43 pm    Post subject: Reply with quote
+1
+2. As long as the price is relevant to the mileage....
EX 997 C2 gen 2 PDK
EX 993 Targa
Rhodris-dad
PostPosted: Fri Mar 15, 2019 3:11 pm    Post subject: Reply with quote
It was due for a service and as it had all it's stamps, I decided to let Hartech have a look at it.
At that time bore scoring was still not that well publicised. I had no idea but they must have had heard the light tapping and did a investigation.
Cannop
PostPosted: Sat Mar 16, 2019 9:25 am    Post subject: Reply with quote
My point is the older a car gets the less important this is. A 100k 997.1 could be a much better buy at the same price as a 50k one depending on the history of both.
I looked for almost a year for my 997.1 and I saw dozens of cars, a lot of them purporting to be around the 50 to 60k mileage mark and a lot at around the 100k mark.
Almost without exception (I say almost!) the 100k cars I viewed had a more honest history than the lower mileage cars, I think this may be because I tended to choose carefully the higher mileage cars I went to see. One of my criteria was 3 or less previous owners and it seemed the owners I met tended to be enthusiasts in the complete sense of the word. The things that turned me off some of the higher mileage ones I viewed wasn't anything to do with mechanical history as on the whole they all seemed very well looked after, it was more the spec levels and colours that I was fussy about.
With the lower mileage cars I widened my net and visited quite a number of dealers and all I can say is it was an eye opener! Exceptional 50 to 60k cars being sold by a dealer command exceptional prices whereas run of the mill tired examples (always with a fully stamped service book strangely enough) seem to be offered at what I'd expect to be paying for a decent example.
Poker2009
PostPosted: Tue Mar 19, 2019 7:21 am    Post subject: Reply with quote
Good luck Thumb
The cost of a rebuild on a Gen 1, would more or less bring you up to the cost of a Gen 2 with no rebuild. Gen 2 is also not 100% bullet proof, and is now a 10 year old car. In my mind, you are better off with a Gen 1, if nothing goes wrong you saved yourself 10-15k.
I am on 9.5 years on a 14 year old Gen 1 with 63k miles, and it is fine.
Drive the car above 3k revs as much as possible (stay in lower gears if necessary), change oil (Millers NT) every year or 5-6k miles (religiously keep it topped up). Keep a close eye on coolant level.
Change the air and pollen filters yourself (Mann from eurocarparts), stretch out the spark plug change to 5-6 years or say 30k miles, and only spend money when it something needs to be fixed (i.e. when the brake warning goes off, I will change the brakes!). Also, 2 year brake fluid change is a waste of money - should be more like 8 year - we live in the UK, not Dubai!
The last stamp in my book was nine years ago (and I don't care about service history nonsense). If tomorrow I have to Hartech rebuild engine, I would just pay it.
997.1 C2S, black, coupe, manual, Feb '05:
65k miles, tiny IMS bearing, Millers NT+ 10W50, driven above 3000 RPM.. original engine.
Page 2 of 3
