964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
-ollie-
PostPosted: Sun Mar 10, 2019 3:59 pm    Post subject: New Seats for Gt3 Clubsport Reply with quote
Guys,
I have a 997.1 Clubsport with the factory buckets. Whilst they look very cool, they're too narrow for me - I am sat "on" the seat, rather than in it. My hips and shoulders are wider than is ideal for this width of seat.
My question is, if I buy a pair of wide Recaro's or similar, will they bolt into the factor side mounts present in my car? Or do I need to consider alternative mounts to allow a greater width? My current feeling is they won't, as they will be wider - perhaps I'm being daft.
If anyone has fitted a wider seat to a CS please chime in, I'd like to get this right first time and not have to deal with the seat contacting the centre console or door etc.
Ollie
Cunno
PostPosted: Mon Mar 11, 2019 8:30 am    Post subject: Reply with quote
Never done this with the fixed 997 seat but I expect it’s the same as other buckets. The side mounts won’t fit so you will need to buy new ones which are compatible with the new seat.
Bret- Krause do a good range which can be sourced from uk suppliers such as Design 911. The issue will be how to fix the harnesses which you need to figure out before committing.
Alternatively you can buy these which have it all figured out for you and allow for a lower driving position.
https://www.bbiautosport.com/products-1/bbi-seat-base-and-slider-kit
I have the GMG racing version of this, down side there about 1-2 kg heavier than standard runners and side mounts.
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
-ollie-
PostPosted: Mon Mar 11, 2019 10:32 am    Post subject: Reply with quote
Cheers Cunno, I'll get what you suggest, lower seat is a plus too.
Harnesses are no problem I don't think as mine bolt into the chassis already with it being a CS.
Cunno
PostPosted: Mon Mar 11, 2019 12:26 pm    Post subject: Reply with quote
Just make sure the seat you buy are compatible with the base. I run Recaro SPG XL seats and would recommend for the bigger gentleman. Also don’t forget about the lap belts connections
-ollie-
PostPosted: Mon Mar 11, 2019 2:11 pm    Post subject: Reply with quote
I'm 6ft3 and circa 85kg - is that similar to you? I can't wait to be more comfortable in mine, the factory buckets are hellish.
Cunno
PostPosted: Mon Mar 11, 2019 2:49 pm    Post subject: Reply with quote
No I’m shorter and fatter Thumb
Cunno
PostPosted: Mon Mar 11, 2019 2:54 pm    Post subject: Reply with quote
The SPG XL will suit your height and the extra width will sort the issue you raised earlier
-ollie-
PostPosted: Mon Mar 11, 2019 7:31 pm    Post subject: Reply with quote
Cheers dude. Have just ordered a pair of Profi PSG XL's to cheer myself up after a rubbish day. Also dropped Design 911 a note to see if they have the BBI mounts in stock, rather than pay the US import charges ordering direct from BBI.
Track day @ Croft today.
5am start, meant to be a relaxing break from work for a day.
Warmed the car through, got some heat in the tyres - first flying lap and lost power steering, red light on dash. Immediately pitted expecting to see the aux belt shredded, nope... it's in one piece.
Crank pulley nut has wound itself undone - rubbish.
Had to get the car recovered to Fearnsport, it's just arrived.
The up's and down's of playing with cars!
Yours is a .1 also from memory, have you ever had this?
Senoj
PostPosted: Mon Mar 11, 2019 7:38 pm    Post subject: Reply with quote
That’s a new one on me. Question
-ollie-
PostPosted: Mon Mar 11, 2019 7:43 pm    Post subject: Reply with quote
It was on me too.
Possible causes range from missed shift & over rev, to it not being quite tight enough from the factory.
I was adamant I hadn't missed a shift, although it went whilst heel & toeing down the box on the start/finish straight.
Matt @ FS has subsequently read the ECU and confirmed I didn't over rev it Laughing
So the theory is it was waiting to go, just happened today. New bolt, pulley and washer to go on, with some loctite!
Rather it happen at Croft than at Spa. Still a rubbish day though.
Senoj
PostPosted: Mon Mar 11, 2019 7:49 pm    Post subject: Reply with quote
Indeed. It’s the ones we get away with that matter most Thumb
-ollie-
PostPosted: Mon Mar 11, 2019 7:52 pm    Post subject: Reply with quote
Slippydiff
PostPosted: Mon Mar 11, 2019 10:18 pm    Post subject: Reply with quote
Not uncommon, likely causes seem to be overevving or some kind of weird sh*t resonant frequencies due to lightweight flywheel fitment....
Pretty sure I remember reading some guys on Rennlist had had issues.
-ollie-
PostPosted: Tue Mar 12, 2019 2:17 pm    Post subject: Reply with quote
Hi Slippy,
Definitely no over rev scenario, Fearnsport has verified by reading the ECU. I was also adamant I hadn't prior to them checking (obviously didn't believe me! Laughing )
The Yanks do seem to think the cause is to do with the LTWFW fitment, but I can't see how this is possible. If a LTWFW was causing such resonance through the crank as to make the crank pulley nut come undone, it would run the bearings within seconds, let alone allow the engine to run long enough to make a bolt come undone on the opposite side.
I don't buy that theory, and think it's something else.
If anyone has a view on the resonance theory from over the pond, I'd be interested to hear it. It doesn't make sense to me!
-ollie-
PostPosted: Tue Mar 12, 2019 3:16 pm    Post subject: Reply with quote
FYI guys, the existing CS seats are not for sale.
Cunno
PostPosted: Tue Mar 12, 2019 7:36 pm    Post subject: Reply with quote
Wise move Thumb
Do you have a LWFW? As standard they have a dual.
-ollie-
PostPosted: Tue Mar 12, 2019 9:11 pm    Post subject: Reply with quote
Cunno wrote:
Wise move Thumb
Yes it has a 964 Cup ltwfw and a 4.0 RS clutch
Roro
PostPosted: Wed Mar 13, 2019 7:22 am    Post subject: Reply with quote
That’s one of the mods I wanted to have done (LWFW), but Fearnsport never got back to me last year ... or was it the year before. Would be interested to know if it was that mod that caused the power steering issue or not Question
2007 997.1 GT3
2017 F87 M2
-ollie-
PostPosted: Wed Mar 13, 2019 9:16 am    Post subject: Reply with quote
I personally can't see how it could be Roro, but would be happy to hear from anyone who is technically minded on engine harmonics etc.
The Yanks seem (to me at least) come up with a variety of interesting theories & fixes for issues which our lot on this side of the pond don't subscribe to.
Fearnsport tell me they have fitted many of these flywheel setups with no issues, and the cause of the crank pulley nut coming undone is simply that it wasn't tight enough in the first instance.
Slippydiff
PostPosted: Wed Mar 13, 2019 11:12 am    Post subject: Reply with quote
Hi Slippy,
I'm with Matty and his views on a lot of stuff the Yanks produce for our cars. But rest assured harmonic frequencies can make stuff come loose whilst having no adverse effects whatsoever on the how the crank bearings function.
Plenty of information about the issue here :
http://performancedevelopments.com/porsche6cylharmonicenginefailure/
Take a look at the images of a failed crank and you'll see the journals are all intact and undamaged.
Don't get me wrong, there are plenty of 996/997 GT3's and 2's running with LWT flywheels without issue, and Matty will know the vast majority run without ANY issues whatsoever, but occasionally there are clearly rogue cranks (or harmonic dampers) or usage that cause a catastrophic failure.
Or the wrong bolt/pulley being used ... :
https://rennlist.com/forums/gt2-and-gt3/693276-gt3-with-light-weight-flywheel-lwfw-you-must-replace-crank-pulley-to-track-diy.html
I've seen truck engines with sheared/snapped crankshafts (because the harmonic damper had failed) and the bearings/journals were all perfect, the only problem was the crankshaft was in two pieces ... !!!
