997 : 2004- 69
Boxster : 1997- 13
Cayman : 2005- 14
IanG1
PostPosted: Sun Mar 10, 2019 12:14 pm    Post subject: Handbrake shoe springs Reply with quote
Started to change out my rear discs today and found the two retaining springs and the short tension spring for the rear handbrake shoes in bits once I removed the disk. Anyone found a source of a full spring kit or individual springs cheaper than what I've just had a quick look at (design911 website)
99635274100 which is the retaining spring at £18,43 each (Need 4)
99735272101 which is the short tension spring at £16.83 each (Need 2)
Almost £120 for 6 springs is a joke, bought complete kits of similar stuff in the past for other cars at fraction of these parts cost?
Any help appreciated on an alternative source
1998 996.1 C2 manual/LSD with aero and a big smile
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Mar 10, 2019 12:29 pm    Post subject: Reply with quote
I was quite shocked when I order my springs from OPC, I didn't ask for a quote as I assumed they would be cheap, I nearly fell on the floor when he said how much on the day I went to collect.
For the 944 I ordered a kit from ebay that was 10 time cheaper, they are supposed to be a similar kit all the way through the models and generations of cars.
IanG1
PostPosted: Sun Mar 10, 2019 1:19 pm    Post subject: Reply with quote
Yes found some that look identical listed for 964/993 at £5 each for retainers and £4.50 each for short tension spring?
IanG1
PostPosted: Tue Mar 12, 2019 8:21 pm    Post subject: Reply with quote
Took a punt and got a pair of 964/993 retaining springs and they are no good as they are too short in the piece that hooks into the hole so £10 wasted never mind. Good news is the short tension spring is identical and listed at £20 so thats £15 cheaper. I also took a punt on these
https://www.ebay.co.uk/itm/VW-LT46-1996-2006-Handbrake-shoe-fitting-kit-brake-shoe-springs-SFK5019A/332403663990?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
And turns out both the shoe springs are identical to the OEM. Porsche want £80 for these so bargain at £8. Had to bite the bullet and get the OEM retaining springs though as the ones in this kit were again too short.
Worth buying a set of the above and sticking in your spares stash just in case in the future.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Mar 12, 2019 8:22 pm    Post subject: Reply with quote
Good info Thumb
