997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
tedzwedz
Location: Ladbroke Grove, London & North Yorkshire, & Isle of Carna - Scotland
1998 Porsche 996 Carrera 2
PostPosted: Sat Mar 09, 2019 6:07 pm    Post subject: Passenger door sometimes doesn't open Reply with quote
Hi
My passenger door doesn't always open when i open the car with the remote.
Normally i have to lock the car again a few times and open or try to open front he inside etc.
Any clues?
Dodgy solenoid?
I've just had ignition key thing replaced which was causing electrical gremlins so I had hoped this was linked but obviously not!
Best Edward
1998 Porsche 911 (996) C2 - GT3 SplitRim 18" Alloys, Oettle Porsche Sports Exhaust, K&N Airfilter, Silicone Cold Air Intake, Quad Exhaust Tips, Litronic Headlights (2008 - )
2012 Piaggio Vespa LX 125ie (way faster than the 911 around London!)
PostPosted: Sat Mar 09, 2019 6:17 pm    Post subject: Reply with quote
Its more than likely going to be the lock mechanism ..
Try spraying the hell out of the door catch with lubricant and then open / close the door many times ..
Its about all you can try other than removing the lock and seeing if its sticking or just plan had it .
tedzwedz
PostPosted: Sat Mar 09, 2019 7:06 pm    Post subject: Reply with quote
So you dont think an electrical gremlin? Interesting, i assumed so!
Best Edward
PostPosted: Sat Mar 09, 2019 7:20 pm    Post subject: Reply with quote
Its possible .. but that would indicate a broken wire or a high resistance in the wires ..
The alarm CU under the passenger seat controls the central locking .. these are prone to water leaks being so low down .. on a cab then it would be the first thing to look at .. But ..
You get many other faults with this type of thing so i discounted it .
A wire break / resistance .. it would be more of a permanent thing so from your desription i also discounted it .
Software fault .. again unlikely and nothing you could actually do about it ... i discounted this as well.
To actually prove its a wiring fault or not you would remove the door card , check the wiring diagram , see which wires actually operate it then check to see if you had voltage at said pins to prove it one way or the other ..
Im happy to check a diagram for you if needed and explain what to do .
The lock might stick or it might be the motor inside thats failing if you have voltage at the wires but a non operateing lock.
Over all i looked at what you said , considered what you can do and boiled it down to a straight forward answer .
Thats the longer version Very Happy
Spray it with lub .. work it a lot then see if it helps .
tedzwedz
PostPosted: Sat Mar 09, 2019 7:21 pm    Post subject: Reply with quote
Thank you very much, good answer! I will try the oil first then go from there, thank you!
