996 : 1997-2005 29
Boxster : 1997- 14
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Mar 05, 2019 8:50 pm    Post subject: 996 and boxster front upright differences Reply with quote
I am looking at buying some more front uprights for some mods I am planning. I have seen 986 boxster and 996 uprights advertised. I can see that the boxster ones are also used on the rear of the boxster so have a hole for the handbrake cable, but otherwise are they functionally the same?
There seem to be a whole load of different part numbers available and no information on what the differences are.
Any ideas?
kurlykris
PostPosted: Tue Mar 05, 2019 9:42 pm    Post subject: Reply with quote
The 996 and the 986 Boxster are supposedly the same up until the A pillar, but looking at the parts lists there are loads of different uprights for some reason, might be worth calling your parts guy at OPC Nottingham Dont know
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
kas750
Reims
2006 Porsche 911
PostPosted: Tue Mar 05, 2019 10:02 pm    Post subject: Reply with quote
I presume there will be different damping rates because of the difference in weight distribution.
MisterCorn
PostPosted: Tue Mar 05, 2019 10:05 pm    Post subject: Reply with quote
It is just the uprights I am interested in. The alloy part which holds the wheel bearing and links the steering arm, shock absorber and brake caliper. Not the shock absorber itself.
I did wonder about different caliper bolt spacing?
kas750
Reims
2006 Porsche 911
PostPosted: Tue Mar 05, 2019 10:13 pm    Post subject: Reply with quote
kurlykris
PostPosted: Tue Mar 05, 2019 10:14 pm    Post subject: Reply with quote
The parts lists refer to it as the "wheel carrier" and it looks like it depends on options fitted to the car Sad
PostPosted: Tue Mar 05, 2019 10:23 pm    Post subject: Reply with quote
According to rosepassion they are the same for '98 cars:
https://www.rosepassion.com/en/cat/porsche-996-1998-996-carrera-2-coupe-manual-gearbox-6-speed/M502/front-axle-assembly/stub-axle-and-hub/B170/wheel-carrier-wheel-hub/I814/wheel-carrier/Z156428/P58193
https://www.rosepassion.com/en/cat/porsche-boxster-986-97-04-1998-boxster-2-5-cabrio-manual-gearbox-5-speed/M478/front-axle-assembly/stub-axle-and-hub/B170/wheel-carrier-wheel-hub/I640/wheel-carrier/Z16464/P58193
ragpicker
Estoril
PostPosted: Wed Mar 06, 2019 8:38 am    Post subject: Reply with quote
The wheel carrier is the same on the Boxster as the 996 C2 front.
The rear suspension on the boxster is essentially a mirror image of the front (unlike on the 996 where the rear is completely different to the front) and you can use a front carrier on the rear but you may need to drill holes to attach brackets etc.
Essentially, the only difference between any of them is whether certain mouldings/blanks have been tapped and whether they are L/R
The wheel bearing itself has had many revisions. I recently had my turbo's wheel bearing changed and its now a 991 part.
Hope thats of some help Thumb
MisterCorn
PostPosted: Wed Mar 06, 2019 8:48 am    Post subject: Reply with quote
That is superb, I hoped that would be the case but didn't want to buy some uprights to find that the brake caliper mounts or steering arms were different.
I shall continue with my cunning plan for a brake upgrade.
