964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Niall996
PostPosted: Tue Mar 05, 2019 8:50 pm    Post subject: What tools for inner wheel arch? Reply with quote
Quick question. Does anyone know what tool is needed to remove the inner lining of the front wheel arch to access the bonnet cable?
PostPosted: Tue Mar 05, 2019 9:01 pm    Post subject: Reply with quote
Phillips screwdriver and a trim tool to remove the plastic clips , the outer part pushes into the inner part and expands it to lock it in place .
Trim tool under the outer part .. you will see it when you look and then lever it out .
Niall996
PostPosted: Tue Mar 05, 2019 9:08 pm    Post subject: Reply with quote
Thanks a mill
