997 : 2004- 74
Boxster : 1997- 14
rich07
PostPosted: Tue Mar 05, 2019 1:11 pm    Post subject: is 993 ride height adjustable as standard? Reply with quote
Hi guys, does the 993 come with adjustable ride height as standard? my 993 has thread on the dampers so I should be able to lower it? I can fit three fingers between the arch and tire currently.....
thanks Rich
94 993 coupe
Cameltoe & Heel
PostPosted: Tue Mar 05, 2019 3:24 pm    Post subject: Reply with quote
I think the standard set-up you can adjust at front only, the rear are fixed.
The chances of you actually getting them to move is another story, they very quickly seize unless threads are treated.
Do you have sports M033 suspension or standard?, I'd say my M033 gives about two fingers gap (at rear anyhow), the front still needs to settle but is sat at about three fingers, I'm likely to adjust downwards.
Trev
rich07
PostPosted: Tue Mar 05, 2019 5:42 pm    Post subject: Reply with quote
Hi, I also have three finger space at the front, two at the rear. Rears also look adjustable but I need to take the wheel of to confirm, I do I confirm if I have the sports suspension setup? I hear what your saying about adjusting them, probably corroded together. ..
rich07
PostPosted: Sat Mar 09, 2019 10:10 pm    Post subject: Reply with quote
Hi guys, so I have adjustable coilovers at the front, no adjustment at the rear. Has anyone replaced just the springs to lower the ride height? If so i would love to know what make spring etc and what size wheels running. The set supplied by design 911 were wrong, so they have been returned.
