997 : 2004- 67
996 : 1997-2005 34
Boxster : 1997- 21
Cayenne : 2003- 3
Slippydiff
PostPosted: Mon Mar 04, 2019 11:54 pm    Post subject: REDUCED !! JRZ 12-31 3 way adjustable dampers 996 GT2/GT3/C2 Reply with quote
PRICE REDUCED to £2495
JRZ 12 - 31 3 Way Adjustable Dampers.
Previously fitted to a Mk1 996 GT3 road/track car. Will fit Mk1 and Mk2 996 GT3/996 GT2/996 GT3 RS/C2 (C2 with the correct front strut top mounts and anti roll bar droplinks) and 3.6 997 Cup car.
Fitted with 600lb (105 N/mm) front springs and 700lb (122N/mm) rear springs.
Purchased off CTR Developments in 2012 at a cost of over £8000.
The dampers have done 7500 road and track miles.
They're not leaking nor do they rattle, but everyone seems to think they need a service/change of damper oil.
Ian Gardiner : http://www.igracing.co.uk/contact.html
has quoted me £250 per damper (inc parts) to service them (copy of quote from IG available) I don't have the necessary time to have the service undertaken, so I've reduced the asking price considerably beyond the cost of the service.
£2,495
Collection only (unless fully insured carriage is arranged)
Please contact me at henmarcu@gmail.com rather than sending me a PM. many thanks.
crash7
PostPosted: Tue Mar 05, 2019 12:54 pm    Post subject: Reply with quote
I run these and can echo the comments on them being about as good as it gets!
Customer service from the guys in the Netherlands is excellent and Ian Gardiner can service / rebuild if required
http://www.igracing.co.uk/dampers.html
Good luck with the sale Thumb
Slippydiff
PostPosted: Wed Mar 06, 2019 2:03 pm    Post subject: Reply with quote
Thank you C7 !!
The JRZs are hugely impressive, and if I didn't have the Ohlins with their road biased spring rates and valving on the shelf, I'd definitely keep the JRZs.
Slippydiff
PostPosted: Thu Mar 14, 2019 10:25 pm    Post subject: Reply with quote
Bump. Price reduced.
Slippydiff
PostPosted: Sun Mar 24, 2019 6:39 pm    Post subject: Reply with quote
Bump.
These will also fit 996 C2 Mk1 and Mk2 when used in conjunction with the correct anti roll bar droplinks and either OE 996/997 GT3 front top mounts or aftermarket items form the likes of Tarett :
https://www.tarett.com/items/996-997-products/996-997-991-suspension/996-997-991-monoballs~bushings/996-986-front-camber-plate-set-996fcplta-detail.htm
Slippydiff
PostPosted: Mon Apr 22, 2019 9:48 pm    Post subject: Reply with quote
Slippydiff
PostPosted: Mon Jun 10, 2019 10:52 am    Post subject: Reply with quote
BUMP Price reduction to £2495 10.6.19
