Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Slippydiff
PostPosted: Mon Mar 04, 2019 11:24 pm    Post subject: Elephant Racing 996/997/986/987 Adjustable Rear Toe Arms Reply with quote
Lowered 966/997's run out of rear toe adjustment range. These Adjustable rear toe links extend the range of adjustment and add bump steer correction.
Adjustable Length - Threaded double adjuster for easy toe settings. The built in bump steer adjustment lets you dial in a minimal bump steer curve. Fully weather sealed - Proper boots at both the ball joint and heim joint ends to keep water and contaminant out for extended life.
The inner Heim joint removes all the compliance found in the standard rubber bush, and thus removes any chance of unwanted rear steer due to the rubber bush distorting under high cornering loads.
These easy to adjust arms remove the need to mess about with the awkward eccentric bolts in the rear subframe.
https://www.elephantracing.com/996-997/adjustable-control-arms-and-links/rear-adjustable-rear-toe-control-arm-track-rod/
https://www.porscheshop.co.uk/our-brands/elephant-racing/elephant-racing-adjustable-rear-toe-links-for-lowered-cars-996-997-boxster-cayman.html
Removed from my Mk1 996 GT3. These have done 7,500 miles, the ball and Heim joints are as new.
£450 Can post at buyers expense.
Please do not PM me. I'd be grateful if you'd Email me at henmarcu@gmail.com please.
