997 : 2004- 74
Boxster : 1997- 14
MikeRSR
PostPosted: Mon Mar 04, 2019 1:01 pm    Post subject: Clear vinyl rear arch stone guards? Reply with quote
Any any suggestions for the best aftermarket supplier, or is OPC parts dept the way to go? Any advice appreciated!
1994 993 C2 Riviera Blue
Jet Jock
PostPosted: Mon Mar 04, 2019 1:18 pm    Post subject: Reply with quote
Just picked mine up from FD Motorsports in California, $95 plus postage.They are very good quality and 3M. I've seen some cheap ones on eBay but wasn't sure of quality. I think OPC charge £66 for each side for the OEM ones.
HTH
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, FD Motorsport SSK and Golden Rod, MPL Clutch Slave Cylinder, HID conversion...
Instagram: bazzar_a
MikeRSR
PostPosted: Mon Mar 04, 2019 5:53 pm    Post subject: Reply with quote
Thanks, just ordered through local OPC Cool
Jet Jock
PostPosted: Mon Mar 04, 2019 9:40 pm    Post subject: Reply with quote
Instagram: bazzar_a
decgraham
PostPosted: Tue Mar 05, 2019 8:55 am    Post subject: Reply with quote
I see that you have already bought the stone guards but I looked a few years back and contacted http://www.prestigeparts.co.uk/ (No affiliation) They were helpful, seemed to know what they were doing and the price was good. They have the ability to change the shape if needed. I did not buy from them in the end as I had the small dent in the RHS rear arch removed, it was so small it was possible to roll it out, and no need to replace the stone guard. However I would look to them again if I needed new stone guards.
ATB Smile
Tobesetc
PostPosted: Tue Mar 05, 2019 11:25 am    Post subject: Reply with quote
Now I'm no expert on plastics... but I've bought/applied a hell of a lot of decals and I am certain that if we could find the pattern (and that's as easy as tracing the shape off my car) we could get them made by someone like Stickeredup4lemans on any 3M clear material we stipulated for a fraction of the cost/numbers people are quoting above!
I bet Carbone would do it. Mind you, they charge Porsche Tax too.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
kingroon
PostPosted: Mon Mar 18, 2019 2:02 pm    Post subject: Reply with quote
I sent in a Best Offer of £40 and got these..
https://www.ebay.co.uk/itm/CLEAR-polyurethane-stoneguard-set-for-rear-arches-of-a-Porsche-911-993-Carrera/230872123666
911smark
PostPosted: Mon Mar 18, 2019 6:02 pm    Post subject: Clear stone guards Reply with quote
I bought mine from prestiege parts or kpporsche on ebay (Keith Pink) Good quality, fitted perfectly.
decgraham
PostPosted: Mon Mar 18, 2019 6:19 pm    Post subject: Re: Clear stone guards Reply with quote
Hi 911smark,
Good to hear that they fitted perfectly. As I said, I would go to Keith too for replacement as I had a chat with him online in the past and he was very helpful.
Can you give us a heads up on how you went about removing the old ones and fitting the new ones please?
ATB Smile
MikeRSR
PostPosted: Mon Mar 18, 2019 6:27 pm    Post subject: Re: Clear stone guards Reply with quote
decgraham wrote:
...how you went about removing the old ones...
Umm, good question!
decgraham
PostPosted: Mon Mar 18, 2019 6:46 pm    Post subject: Re: Clear stone guards Reply with quote
MikeRSR wrote:
Umm, good question!
I think I know where you are coming from. I had both mine replaced by OPC in Kuwait back in 2010 before I exported the car to the UK. The guy at OPC Kuwait said it took him a whole day to remove both stone guards, they came off thumb nail piece by thumb nail piece. They were 15 years old by then and had been subjected to some pretty high Kuwait summer temperatures of 52C Cool
They did a good job though. Very Happy
ATB Smile
911smark
PostPosted: Tue Mar 19, 2019 6:38 pm    Post subject: Stone guards Reply with quote
Decgraham, I did not fit them myself, my body shop guy did, However I think he removed the old one's with a hairdryer / heat gun and then used plenty of soapy water to apply the new one's.
kingroon
PostPosted: Wed Mar 20, 2019 9:03 am    Post subject: Reply with quote
Mine was a slightly more aggressive means of removal..!
 Filesize:  253.03 KB
 Viewed:  883 Time(s)
 Filesize:  205.52 KB
 Viewed:  883 Time(s)
Lig
PostPosted: Thu Mar 21, 2019 5:38 pm    Post subject: Reply with quote
Hi all,
I am sure the OEM guards are made by Orafol and are 'Oraguard' material. I bought a pair from Keith from eBay and they were Oraguard, but then my bodyshop messed the first one up (by not fitting with water) so I ended up getting a replacement from Keith, but sadly this wasn't Oraguard (it states this on the backing tape) Keith told me the Oraguard ones were too expensive and the replacement wasn't as good. I ended up fitting both, dead easy, just use lots of water with a tiny bit of wash liquid, then squeegee all the water and bubbles out from underneath again with plenty of water as lube. The Oraguard one is clearer. Not that the other looks bad, and you wouldn't notice. But given the choice Oraguard are the ones.
I now buy Oraguard in a roll to use on my bikes for cable rub and chainstay protection... its the best helecopter type tape out there!!
Lig.
993 C2 Midnight Blue | Turbo twists | Bilstein B6 | Fister stage II | Dansk 200 cell Cat | Recaro Pole Position | Momo Prototipo SW | Becker Traffic Pro | No rear wiper Wink | Headlamp washer delete
pzero
PostPosted: Fri Mar 22, 2019 8:00 am    Post subject: Re: Stone guards Reply with quote
Yep, seems to be the trusted way.
http://www.911uk.com/viewtopic.php?p=931539&sid=3c2eb6c6b7e616fe010b6fd85f8e10bb
991.1 Carrera GTS
