996 : 1997-2005 29
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Lordjimimac
PostPosted: Sun Mar 03, 2019 8:51 pm    Post subject: Door latch mechanism questions Reply with quote
Hi folks,
My drivers side window has started to sometimes raise to full height when the door is open (rather than staying slightly lowered to allow it to clear the door frame when closing). Research suggests it’s highly likely to be a knackered micro switch in the door latch mechanism, and I’ve a couple of questions that would be of great help if anyone knows the answers:
- when replacing the mechanism, Will I need a new door membrane or is it possible to not knacker the existing one?
- would I be best sourcing the part from opc or are there other suppliers that are cheaper?
- if anyone had done this job, is it poss for an amateur to DIY?
Big thanks for any help on these qs.
James
997.1 C4S (Atlas grey, black) - current
E92 M3 DCT Comp pack (space grey, black)
E90 M3 6MT (Silverstone II, palladium)
996TT (artic silver, metropole)
E39 m540i (Titan silver, black)
987S (Lapis, metropole)
Z4M coupe (blue, cream)
S2000 (red, black)
Mini Cooper S Works (blue, black)
Alfa 145 Cloverleaf (red, black)
DucatiRob
PostPosted: Sun Mar 03, 2019 9:12 pm    Post subject: Re: Door latch mechanism questions Reply with quote
Lordjimimac wrote:
Hi folks,
James
James, there isn't a membrane as such, it's an aluminium inner door skin, you won't need to replace this but the rubbery/foam seal around the edge that sits against the door frame will almost certainly come apart and will need to be replaced. It's the seal that is the culprit of many a wet door carpet! Removing the residue of the old seal is a pain, but necessary to prevent leaks. I used some roofers mastic, messy but does the job Thumb
Mercedes CLK DD
Ducati 996
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Sun Mar 03, 2019 9:14 pm    Post subject: Reply with quote
Have you tried YouTube for a ‘how-to’?
DeMort has shared his usual outstanding advice on this thread just before you posted.
Deroure parts diagrams always useful.
http://911uk.com/viewtopic.php?t=132644&highlight=&sid=f31147d1689125cec3b29b3289e20bec
I assume you have tried resetting the open and closed positions of the windows from inside the car with door closed?
Lordjimimac
PostPosted: Mon Mar 04, 2019 8:36 pm    Post subject: Re: Door latch mechanism questions Reply with quote
Thanks loads for the cautionary insight!
DucatiRob wrote:
Lordjimimac wrote:
Hi folks,
James
S2000 (red, black)
Lordjimimac
PostPosted: Mon Mar 04, 2019 8:36 pm    Post subject: Reply with quote
Wow amazingly helpful - thanks!!
S2000 (red, black)
DucatiRob
PostPosted: Mon Mar 04, 2019 8:48 pm    Post subject: Reply with quote
I had a similar problem with the door mechanism on my Audi TT some years ago, the microswitch had failed, Audi wanted £175 for the whole mechanism as they didn't sell the switch on it's own, found an almost identical switch from Maplin for about £2, not sure if the switch on the 911 is replaceable, but worth a try!
Mercedes CLK DD
Ducati 996
