964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
PostPosted: Sun Mar 03, 2019 5:30 pm    Post subject: Suspension Top Strut Mounting ----------------- Reply with quote
Hi all, as im looking to fit my Techart Lowering Springs and soon to purchase a set of B6, im also looking to get new Suspension Top Strut Mounts,
question is ...
What make is the Strut Top Mounts that Porsche use on the 997 ??
J
-- 997 --
PostPosted: Mon Mar 04, 2019 11:43 am    Post subject: Reply with quote
Anyone?
Milo72
PostPosted: Mon Mar 04, 2019 2:59 pm    Post subject: Reply with quote
Sorry can’t help you in the original Porsche part but I’ve just fitted techarts and replaced the top mounts with ones from Design 911.
997.1 C2S Cab Tip.
geoffers
PostPosted: Mon Mar 04, 2019 6:05 pm    Post subject: Reply with quote
Pretty sure eBay item 192794966601 will do the job...
Sachs pattern part, at £24 each including postage.
997.1 C2 Coupe
GMG
PostPosted: Mon Mar 04, 2019 7:31 pm    Post subject: Reply with quote
...just replaced mine and prior to buying them spoke with Centre Gravity whom strongly advised against buying the cheapo ones and it's better buying them from Porsche which is what I opted to do...they said that the cheapo ones don't last very long...
-- 997 --
PostPosted: Tue Mar 05, 2019 6:57 am    Post subject: Reply with quote
Thanks for your replys, ill check the sachs, porsche are pretty nuch gonna be pricey still !!
K
weebz
PostPosted: Tue Mar 05, 2019 8:49 am    Post subject: Reply with quote
I think they could be Meyle, but more than likely Porsche probably had several manufacturers doing them, circa £70 each from OPC.
PN for 2wd is 99734301801
2010 Basalt Black 997 Carrera S - 'J-Lo 2'
2004 Atlas Grey 996 C4S - 'J-Lo' (sold)
