997 : 2004- 77
Boxster : 1997- 15
Cayenne : 2003- 3
Allan E
PostPosted: Fri Mar 01, 2019 11:20 am    Post subject: Creaking windscreen Reply with quote
Can I have some advice either short term or long term on how to rectify the creaking which appears to be coming from the front screen. The problem has suddenly come to light in the very cold spell of weather we experienced in early February, prior to this hardly anything.
I am assuming it is the windscreen and not just something behind the dash.
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
Cameltoe & Heel
PostPosted: Fri Mar 01, 2019 11:47 am    Post subject: Reply with quote
Has the screen been replaced recently?, if so by who?, is it an OEM screen?.
Trev
graemeho
PostPosted: Fri Mar 01, 2019 12:16 pm    Post subject: Reply with quote
It's a known issue I'm afraid. There is a porsche bulletin showing to pump the cavity full of silicon sealant. Should be an old thread on here if you search.
I fixed mine on my old cab by lifting the rubber seal and pumping it full of silicon wax (aka the stuff you use to lubricate bike chains with). Halfrauds finest
Cayman GTS
takeflight
PostPosted: Fri Mar 01, 2019 12:33 pm    Post subject: Reply with quote
I had the same problem when I had some body work done and they organised a fitter to remove and replace. However mine had a crack so after research I used http://www.glasstecpaul.com/problems-with-a-porsche-993-windscreen/
Paul came and fitted the new one, when he removed the old one half of the bottom edge had sealer applied but it wasn’t positioned correctly so there was gap.
AndyS
PostPosted: Fri Mar 01, 2019 1:24 pm    Post subject: Reply with quote
I had a new screen fitted about 18 months when I had the respray. Everything had been fine.
I went out on new years day in the ice and the screen was creaking.
I next went out at beginning of Feb when it was really cold - and it was annoyingly creaky, so much so that I decided to take it down to 9M to get them to have a look the next dry day we had.
On that day though, it was nice and warm and there was no creaking!
Last week in the sun - no problem.
The fix then is to have the window down and revs up when it's cold out Grin
Andy
sday12
PostPosted: Fri Mar 01, 2019 2:33 pm    Post subject: Reply with quote
+1 for Paul (Glassman) perfect job.
https://www.pistonheads.com/gassing/topic.asp?h=0&f=48&t=1155517
1997 Schwartz Black Manual 993 Carrera 2S Hardbacks/Hollow Spokes + Tequipment goodies
PostPosted: Fri Mar 01, 2019 4:23 pm    Post subject: Reply with quote
Absolutely a +1 for Glassman's work. He sorted out my 996 when it had similar creak issue.
Sadly, for Allan E, there's no way he'd travel from North London to Tyne & Wear.
Allan E
PostPosted: Fri Mar 01, 2019 4:31 pm    Post subject: Reply with quote
Trev
The screen is the original I believe however would the screen not have been fixed with some sort of silicone based bonding agent, or does it sit between the inner and outer seals?
Can I assume to apply silicone I would remove the outer seal, reseal then replace the outer seal, preferably using a new one?
Allan E
PostPosted: Fri Mar 01, 2019 4:56 pm    Post subject: Reply with quote
Many thanks for the replies, just been scanning another forum and “ Pedros Ice Wax” is mentioned, has anyone used this stuff and if so does it work?
PS I have tried the open windows and plenty of revs but it still gets on my wick!
PostPosted: Fri Mar 01, 2019 8:31 pm    Post subject: Reply with quote
996 suffer from this as well .. we use Teflon tape .. it looks like selotape but a bit more expensive ..
You lift the screen rubber and fit this tape all the way around the screen .. it basically proves a surface the screen rubber can slip on rather than drag which causes these noises ... you do have to trim it to fit though .
Citori
1996 Porsche 993 Carrera 2
PostPosted: Tue Mar 05, 2019 8:11 am    Post subject: Reply with quote
I replaced the outside screen rubber for a new one and that stopped my screen creaking. It seems that the rubber hardens over time and starts to creak.
The replacement screen rubber was about £30 from the OPC.
Previously enjoyed Porsche:
1996 C2 Coupe.
1983 911 Carrera Targa Sport.
1981 911SC Sport.
1978 911SC.
1970 911E.
I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE..
Aircooled or nothin....
A993LAD
PostPosted: Thu Mar 07, 2019 2:13 pm    Post subject: Reply with quote
I guess the real solution to this is have the screen properly fitted by an expert.
But if you want a cheap low cost or temporary solution then I would recommend Pedro's Ice Wax. This was recommended to me when I had a 993 coupe with a squeaky screen and never heard a squeak for two years after the initial application of Pedros. Don't know how long it lasted because I sold the car to somebody else.
Nowadays I drive a 993 Cab and the screen may well creak for all I know but it's so noisy with the wind noise and other rattles that I'm not sure I would hear it. And with old age my hearing is not what it was either!
You can buy Pedro's ice wax of eBay and I think it's about a fiver. Just lift up the rubber surround and squirt the ice wax behind it then wipe off any excess.
Good luck squeaky boy
Pretzel
PostPosted: Thu Mar 07, 2019 2:47 pm    Post subject: Reply with quote
Steve
Is it just a case of pulling the old seal out and pushing a new one in or is there more to it?
993 C2 Aventura
wilsonny
PostPosted: Thu Mar 07, 2019 9:44 pm    Post subject: Reply with quote
Steve
yep it just pushes in... new ones look to short when you start... it sort of stretches as you go.... while it's off there is a Porsche tech note which describes filling the gap with sealant to avoid water collecting.
1996 C2 manual
Allan E
PostPosted: Fri Mar 15, 2019 11:58 am    Post subject: Reply with quote
After getting some Pedros Ice Wax, I applied a generous coating all along the lower screen area under the outer seal and left for 24 hours. Went out in the car the following day on an unexpected journey and after 10 minutes or so I realised the creaking had stopped, I will put more in soon and see how long it lasts.
Mark w
PostPosted: Fri Mar 15, 2019 3:09 pm    Post subject: Reply with quote
I had the horrible creaking/squeaking screen problem too, I just had the windscreen replaced for the £75 excess it cost on the insurance it was the best money I could have spent. I also timed the fitting of the new screen to coincide with a service so it was done at a Porsche specialist who could ensure the guy who came out to was guided on how to do it properly!.
nice new screen, no noise at all anymore.
Of course I don't condone anyone making cracks in their windscreen on purpose Judge Floor
AndyS
PostPosted: Wed Apr 03, 2019 8:16 pm    Post subject: Reply with quote
Hi Guys - I got some of this 'Pedro's Ice Wax' today. This may seem a daft question - but where do you put it?
Do you pull the top seal out and just run some in there?
My creaking actually sounds like it comes from the inside...?
Anyone done this?
Andy
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Wed Apr 03, 2019 8:27 pm    Post subject: Reply with quote
Almost £1,500 to replace the screen and rubbers now. Porsche part prices are nuts. Surprised
Allan E
PostPosted: Thu Apr 04, 2019 10:26 am    Post subject: Screen creaking Reply with quote
Andy, gently raise the outer seal (the side away from the glass) and squeeze the wax under. You will need to go from one side to the other and put a good amount in. Because I was fittting a new outer seal I put wax all around the screen however it is always the lower edge that causes the creaking. My first dose of wax, prior to the new seal was just in the centre lower part adjacent to the wipers and that immediately stopped the noise.
AndyS
PostPosted: Thu Apr 04, 2019 11:36 am    Post subject: Re: Screen creaking Reply with quote
Cheers Allan Thumb
Andy
