997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Thu Feb 28, 2019 2:15 pm    Post subject: Who's got a golden rod, or RS linkage, or both? Reply with quote
Is it worth doing?
Not really had any issue but I was reading somewhere one tightens up the feel, the other makes the shift feel closer together.
Suspect it has been asked before so probably should do a search. I think nickjonesn4 did it recently? Pistols
Chief
PostPosted: Thu Feb 28, 2019 2:33 pm    Post subject: Reply with quote
I have fitted both and replaced all bushings.
A very different feel. Box is notchier (if that's a real word) but for my application on The Red Baron it suits. The short shift is noticeable but I have ended up fitting a Function First extended shift lever as if falls to hand better. This may have increased the throw a little but now the set up feels just right.
All that rubberyness (again....) has gone. I can feel it engage the gear. This might be a little mechanical for some
bye
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
Instagram - @chiefporsche
Cameltoe & Heel
PostPosted: Thu Feb 28, 2019 2:34 pm    Post subject: Reply with quote
Done mine very recently (both SSK & Goldenrod), not had chance to drive it yet but I've heard it's a very worthwhile upgrade.
If doing make sure you swap out the thin white shims that hold the mechanism in place.
Trev
Jet Jock
PostPosted: Thu Feb 28, 2019 2:55 pm    Post subject: Reply with quote
I'm having the SSK and Golden Rod as we speak. I also replaced the clutch slave cylinder last year with the MPL product which improved clutch feel and movement. I'll report back when i get the car back in the coming weeks.
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, FD Motorsport SSK and Golden Rod, MPL Clutch Slave Cylinder, HID conversion...
instagram.com/bazzer_a
tim993
2016 Porsche Boxster 981
PostPosted: Thu Feb 28, 2019 3:04 pm    Post subject: Reply with quote
Just the RS shift rod (964 part number). At the time, what with the need to ship the goldenrod from the US and pay customs etc and given Porsche will give 10% off for PCGB AND the fact they had one in stock when I needed it - I decided the RS part was the easiest option Smile
An excellent modification, in my view.
Sharpens up the shift.
Adding an SSK to a turbo is less straightforward due to the drive shaft and as its not a car you need to flick through the ratios on as often as an n/a machine, I wasn't sure I'd benefit from it.
That said, the SSK is on my list of things to discuss with the Mr Sanger Smile
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
Tobesetc
PostPosted: Thu Feb 28, 2019 4:39 pm    Post subject: Reply with quote
I think the 4WD variants are less straightforward for the SS as some...bespoke bodywork... (ie a whack or two with a hammer) is required for it to fit! "For that reason, I'm out".
I would be very interested to compare one with this mod v one with new standard bushes/linkage. <this is never going to happen>
Go for it.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Photos at TobesEtc.com (work in progress)
snb993
PostPosted: Thu Feb 28, 2019 5:40 pm    Post subject: Reply with quote
I had the RS SS from Gert 15+ years ago when I had my 993C4 and loved it. Visually, the bottom of the gaitor could just about be seen underneath but nothing otherwise
In fact I liked it so much that when we had a 993 C4 gearbox & front diff installed into our 964 C4, we opted to have it again (also bought from Gert). the 964 has a central panel in the underfloor pans which is separate from the main ones (can't remember if this is the case in a 993? Question ) and that needed 'adjusting' but that was all. Very minor work
very sweet gearchanges now Thumb I would recommend it - great product and good value
HTH
thumbsup
996T - Cobalt blue, K24's, GT2 I/C's, Techart SSK, Manthey KWv3, H&R ARB's, RS engine mounts, Europipe, GT3RS 6 pots, 997T discs/RS29's all round etc
964 C4 - GP white, 993 C4 gearbox/front diff, Wayne remap, Bilstein B6's / H&R springs, polybushed, Cup 1's, RS SSK, gutted cat etc
993C4 - sold
928S4 - sold
Cameltoe & Heel
PostPosted: Thu Feb 28, 2019 5:48 pm    Post subject: Reply with quote
HTH
thumbsup
You got to make sure you switch the oval rubber/plastic parts 180 degrees, these hold the shaft in place, the RS SSK requires them to be rotated OR you will have issues with clearance at the bottom.
Trev
Endoman
PostPosted: Thu Feb 28, 2019 6:17 pm    Post subject: Reply with quote
Highly recommended. Porsche SSK from Gert and Goldenrod from FD. The reduction in stick travel isn't a lot but the precision of gearchages a delight coupled with RS engine mounts. Transmission mount did not make a noticable difference other than slight noise increase.
Wish I could get the same feel with the 944 but on the otherhand the handbrake is much better on the 944.
I changed the gearbox oil from Mobil FHC to the Porsche (Shell I think) oil.
No difference to changes but chatter is worse from the LWF.
Another great mod is the MPL slave cylinder especially for stop start driving. A remote bleeder is a tricky but great thing to do.
harryk
PostPosted: Thu Feb 28, 2019 8:29 pm    Post subject: Reply with quote
Had the SSK and Goldenrod fitted and the MPL cylinder. The combination had a great effect in my opinion: the shorter throw and feel of the shift made it worth it imho.
Mine is a C4: the "modification" required a few blows with a mallet. Nothing dramatic, and it's to an easily replaced cover/panel should you want to change it back.
1995 993 C4 Coupe. Schwartz/Flamenco Red soft nappa leather. Exclusive leather everything, Exclusive extended centre console, MO33 suspension set up by CG, Chipwizards 287bhp remap, FDM Goldenrod & SSK, Techart exhaust, Techart pedal set, Tequipment dials, Tequipment handbrake & gearlever.
Instagram @hskular
wilsonny
PostPosted: Thu Feb 28, 2019 8:44 pm    Post subject: Reply with quote
I've just got the rs shift (plus all bushes etc), haven't felt the need for the goldenrod. feels great to me as it is... makes what feels like a noticeable improvement in acceleration due to the quicker shift.
1996 C2 manual
tyinsky
PostPosted: Fri Mar 01, 2019 10:05 pm    Post subject: Reply with quote
Thanks everyone, some good feedback and advice. 👍
Normski298
PostPosted: Tue Mar 05, 2019 9:32 pm    Post subject: Reply with quote
Another vote for the FD Golden rod. I haven't bothered with the SSK as I'm not bothered by the length of the throw and didn't want to mod underneath (c4). The golden rod in my view sharpens up the gear change measurably and is possibly one of the best mods on a 993.
993 C4 Schwarz Perl
_____________________
1999 Mercedes C43 AMG
Previously:
993 C2 manual Guards Red
993 Targa Midnight Blue
tyinsky
PostPosted: Tue Mar 05, 2019 10:47 pm    Post subject: Reply with quote
Carnewal is doing the Porsche RS rod and SSK for £170 delivered ATM. Seems a pretty good price 🍩
highway
PostPosted: Wed Mar 06, 2019 8:29 am    Post subject: Reply with quote
From memory the FD goldenrod is a fair bit different to the Porsche rod. It’s certainly way more expensive. The goldenrod and SSK make a lovely difference to the 993 gear change. Worth having done.
Endoman
PostPosted: Wed Mar 06, 2019 9:55 am    Post subject: Reply with quote
The Goldenrod is a copy of the RS rod. When Jackal amd I did mine the Goldenrod was considerably cheaper than the RS one.
Gert's deal seems a bargain.
A precision u/j is available at an extortionate price and appears to be a std VW part.
If fitting to an early car the boot will need to be changed to the later type. I think the update was 1996.
http://www.jackals-forge.com/lotus/993/993_diary_2010.html#goldenrod
tim993
PostPosted: Wed Mar 06, 2019 6:04 pm    Post subject: Reply with quote
It would certainly have been cheaper to order a Goldenrod - however as going for the upgraded rod was a last minute decision while the car was in for its service, I didn't totally begrudge the extra £100 or so... better forward planning though is always a good idea!
Your post though has just cost me half an hour+ on Jackal's forge - so clear, readable and unpretentious. fabulous stuff worship I wonder what happened to his 993 - I presume someone on here or PH now owns it Dont know
1995 993 turbo
andyobro
PostPosted: Wed Mar 06, 2019 6:40 pm    Post subject: Reply with quote
Do you have a link to the whole lot for 170? Been thinking about doing this for a while.
993 Carrera
www.instagram.com/993andy
tyinsky
PostPosted: Wed Mar 06, 2019 11:07 pm    Post subject: Reply with quote
http://www.carnewal.com/products/993/p93104-C2/Short-Shifter-for-every-C2-with-manual-transmission.
Email Gert and he will put together a price with the shipping and taxes. Was just under 200 EUR.
Porsche quoted me £600+VAT for just the rod today and £33+VAT for the shifter. I'd move fast on the Carnewal deal if you want one. KungFu
The shims that were very kindly thought about and pointed out above are a couple of pounds. thumbsup
tim993
PostPosted: Thu Mar 07, 2019 11:42 am    Post subject: Reply with quote
i think I paid about 330 for the RS shift rod - but that was maybe 3 years ago. Now 600??????? that is crazy
1995 993 turbo
Goto page 1, 2, 3, 4  Next
Page 1 of 4
