Miss Piggy is misbehaving.
Its not a big problem but there's definitely a hesitation at partial throttle at low speed.
I've read lots about coil packs and spark plugs causing an issue but I've done those.
At one point I had a valve timing fault code which I cleared (wasn't sure if it had been there since the PO had the car) which hasn't returned.
Do the variocam solenoids play up on these? Will this cause the symptoms. Anyone got any ideas?
