997 : 2004- 73
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
darkhorse
PostPosted: Tue Mar 19, 2019 5:16 pm    Post subject: Reply with quote
So, I am massively struggling to get a workshop manual for the 997.1 T, which is a real pain in the backside. If anyone knows where I can get one I would be very grateful. It's the first car I have had this much difficulty getting a manual for!!
easternjets
PostPosted: Tue Mar 19, 2019 5:48 pm    Post subject: Reply with quote
I've sent you a copy. Don't think that is a tensioner, I had a leak from another plug on the O/S of the bottom of the engine block.
Best to msg Demort he'll know for sure, best to do that before I encourage you to remove it!!
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
darkhorse
PostPosted: Tue Mar 19, 2019 6:50 pm    Post subject: Reply with quote
Cheers. Thats the parts manual so cant really assist with my query over this bit sadly. Other thoughts are it is a chain guide, but until I get my hands on a tech manual Im struggling on this.
I found that I can get the info on Piwis online. But guess what, the site doesnt work properly!
I will pm demort, many thanks
easternjets
PostPosted: Tue Mar 19, 2019 7:29 pm    Post subject: Reply with quote
Demort is your best and safest bet. Had a look myself and it looks like an access plug, chances are it just needs removing, cleaning and a new seal.
997 Turbo Gen 2
Porsche 928 S4
PostPosted: Tue Mar 19, 2019 7:40 pm    Post subject: Reply with quote
Pm sent ..
Its been about 7-8 years since ive pulled one of these appart and im afraid that contrary to popular opinion here i Dont know every part of every Porsche ever built ..
It would be nice though Very Happy
It looks to me like there is 3 seperate oil leaks with the n/s/r one being the chain guide bolt or above that and running down .. it will have a rubber seal on it.
Its also not something you can just undo if it is that thats leaking ..
With any oil leak .. clean off the entire area .. brake cleaner .. leave that to dry then run up the car and look top and bottom for where the leak is coming from ..
Its often not from where you think .
Edit ..
Just for info .. Porsche stopped making paper or online manuals for every market other than the USA from 2004 .
USA with their rules insist on a hard copy .. there is NO UK equivelent manauls for any car after this date , USA copys are as rare as hens teeth im afraid .. its all online these days ... its called PPN .. Porsche Private Network .. you need to be an OPC to have access .
darkhorse
PostPosted: Tue Mar 19, 2019 8:26 pm    Post subject: Reply with quote
thanks demort. pm replied to also!
The leak was cleaned down with brake cleaner and it is definately coming from there with no signs of leaks from anywhere else, either above or below! But will go and have another check with them tomorrow.
Will have to speak to Statler or someone of that ilk and see if I can get it there for the required fix if needed because this garage doesn't have the Porsche timing tools and wouldnt be able to remove the chain tensioner as a result (and nor would I want them to).
The return of Marty Wild
PostPosted: Wed Mar 20, 2019 6:30 am    Post subject: Reply with quote
From the perspective of casual observer, I’ve enjoyed this thread. Appreciate it must be more emotive for the OP.
Hope it all sorts out, sounds promising so far.
Cayman S 987.1
PostPosted: Thu Mar 21, 2019 12:01 am    Post subject: Reply with quote
Could be bargain of the century worship
He who dares Rodder's...He who dares... Grin
darkhorse
PostPosted: Fri Mar 22, 2019 12:05 am    Post subject: Reply with quote
He who dares indeed Grin I'm either brave or stupid, or most likely both!!.
Lots of work done on the car, all coolant pipes at the front (the front pipes werent leaking but there was evidence of greenery on a few joints and they needed doing); the engine bay ones and the long ones have been done under warranty luckily in recent times so they are like new. Radiators are all new last year and so are aircon condensers Exhaust all sorted and turbo studs etc... Now the turbos are bolted up properly it has highlighted one of them has an exhaust gas leak between hot and coldside and you can hear/feel it losing boost when driving enthusiastically. nooo
So I am taking it home and going to get both turbos removed and rebuilt (hopefully) or a new pair. Upsetting Grin but apparently a very common issue according to the turbo specialists i have spoken to on a lot of 997t's now, especially if they have seen uk roads in anything other than dry weather. (corrosion on the hot side casing that thins the cast to the point it starts blowing) Will update this once I have it back home with a few pictures of the ensuing work. I think it will be a total PITA getting the old ones off but it must be done and I have done much worse.!
darkhorse
PostPosted: Fri Mar 22, 2019 12:06 am    Post subject: Reply with quote
Keep an eye out for the updates!! I am sure it will become more interesting as I near the finish line!
easternjets
PostPosted: Fri Mar 22, 2019 9:41 am    Post subject: Reply with quote
Sounds like you'll have a well sorted car by the time your done.
When you mentioned pipes looking 'greenish' didn't you mean 'pinkish' as you should have it filled with the pink/red coolant.
Have you def diagnosed the pressure leak as a duff turbo? There are lots of other places you can loose pressure, also if one of your actuators is not functioning correctly you can have the same issue. I had an issue with an actuator and a pipe blowing off from the turbo unit. If an actuator fails you tend to loose pressure back through the dormant turbo, you'll get barely .2 bar on the gauge and the car juts doesn't pull like it should.
997 Turbo Gen 2
Porsche 928 S4
darkhorse
PostPosted: Fri Mar 22, 2019 10:17 am    Post subject: Reply with quote
Sorry, was late. By green I meant externally on one of the pipe joints (eg an old leak possibly), the coolant in the system is pink . On inspection the pipe joints were not in great condition. The coolant system has also now been vacuum tested and is totally airtight. There wasn't a leak on the front coolant pipes before, but I had them all replaced because the garage has done lots of these on 911's and it seemed like a better thing to do now than wait for problems down the line.
Its definately a duff turbo unfortunately. Now the exhaust is airtight it found the next weak link and you can see soot stains on the joint from exhaust housing and if you hold some paper next to the leak, it flaps from the leakage!! The other turbo has a micro soot stain but no leakage, but I dont think its far behind condition wise.
Thanks regards the actuator, thats interesting. When I get the turbos off I will be sending them to the specialists to investigate and they will assess them both and rebuild including new actuators I think. Apparently these turbos (on 997t's) are starting to corrode from general uk exposure and the metal thins until it gets to the point where exhaust gas pushes out. It is not necessarily a visual inpsection that confirms it they said.
The repair kit they are doing is to strip turbos, machine the problem face out, weld a stainless steel pre machined plate in, and refurb the turbo to new.
They can only do this though if the turbo is not too far gone... so if the metal is too thin, its new turbo time. Currently about £3500 each off Porsche or the best price I have found of £2050 plus vat each from an independant supplier but for the same oem units. (unless anyone knows of better!)
I was tempted to get some hybrids and fit some new intercoolers and get a remap (and whatever else is needed), but common sense is telling me to stay stock OEM!
easternjets
PostPosted: Fri Mar 22, 2019 3:44 pm    Post subject: Reply with quote
I was thinking the hybrid route as I was writing my reply but from what I gather you need to do a lot more on top of the hybrid turbo's to gain full advantage from them.
If you've got 10 to 20 k spare go for it!
The other problem is when you start modifying the car, even upgrading the exhaust it starts to become a non stock Porsche and you'll find it harder to sell.
A lot of the mods I've done to my Gen 2 are easily reversible in a morning and no remaps have been done so the car is as it was when new.
Besides that you've got one hell of a quick car even in std form. Very Happy
Try contacting 9e to see if they have any std turbo's lying around.
997 Turbo Gen 2
Porsche 928 S4
Goto page Previous  1, 2, 3
Page 3 of 3
