964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Littlered996
PostPosted: Sun Feb 24, 2019 7:50 pm    Post subject: Battery charging options Reply with quote
Hi all.
I have the usual winter battery woes and have invested in a CTEK CT5. I have no power in the garage, so it will be a question of occasional charging, rather than trickle charge. The options seem to be (1) park the car outside the house and run an extension cable across the pavement or (2) remove the battery and charge it in the house.
I’m nervous of removing the battery and would prefer to charge it in the car. Is the only option to attach the charger to the battery direct, or can I use the jump start points in the engine bay?
Simon
moorhouse
PostPosted: Sun Feb 24, 2019 9:04 pm    Post subject: Reply with quote
You can buy an extra lead that allows you to charge directly through the "cigarette lighter" or whatever you are supposed to call the 12V socket in these non-smoking days. The Ctek should also come with a set of short leads with rings you can attach direct to the battery terminals which will replace the crocodile clips. Can't imagine its a great idea to have to keep dis- and re-connecting the battery - bound to scramble some bit of the electrics, codes etc.
If you don't have power what about a solar charger - never used one myself so not sure how good they are, especially in a dull winter.
Cheers..Ian
40th Year Anniversary #698
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Feb 24, 2019 9:17 pm    Post subject: Reply with quote
No problem with disconnecting the battery. Key to ignition position 1 and remove it. You will need to enter the radio code and reset the clock when it is reconnected. The only problem is that you can't lock the passenger door with it disconnected. Mine is probably disconnected 10 times a year for one thing or another.
I would connect eyelets to the battery and run an extension lead. Taking the battery out regularly would be a real pain.
Pip1968
PostPosted: Sun Feb 24, 2019 9:21 pm    Post subject: Reply with quote
I think the jump points in the boot are fine or the cigarette lighter or you can just run the connector to the edge of the bonnet (I cannot find GT4's post on this but he extended the Optimate connector so that there was no need to pop the bonnet for connection or disconnection of the trickle charger).
Pip
PostPosted: Sun Feb 24, 2019 9:36 pm    Post subject: Reply with quote
Welcome
Rojdog
PostPosted: Sun Feb 24, 2019 10:12 pm    Post subject: Reply with quote
I have a ctek and find the cigarette lighter attachment the most useful. I first had the battery wired onto the quick connector they also sell but found the wires draping out of the bonnet over the wing started to mark the paintwork after a while.
The cigarette lighter also has a handy traffic light led indicator for battery state. Easily plugs into the passenger foot well socket.
Littlered996
PostPosted: Sun Feb 24, 2019 11:53 pm    Post subject: Reply with quote
Great. Thanks one and all. Sounds like the lighter socket’s the way to go. I thought maybe that was just for trickle charging.
I know you like a photo.
 Filesize:  1.19 MB
 Viewed:  735 Time(s)
PostPosted: Mon Feb 25, 2019 12:54 am    Post subject: Reply with quote
The thread started by GT4 referred to earlier is this one.
--> http://911uk.com/viewtopic.php?t=47741&start=0&postdays=0&postorder=asc&highlight=optimate
Welcome to 911uk littlered'. Pretty car Thumb
Marky911
Watkins Glen
PostPosted: Mon Feb 25, 2019 7:37 am    Post subject: Reply with quote
Welcome little red 996. Thumb
Lovely colour. Is it Velvet red. Rare on a 996.
I have done what MC suggests and have a lead I made up with eyelets. I fit it to every car I buy and have an extension piece to get from that lead to the charger.
Cigarette lighter is another easy way though, as mentioned.
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Mon Feb 25, 2019 7:54 am    Post subject: Reply with quote
I normally just plug in at the battery terminals, leave the charger and extension lead in the trunk, the lid closes on the wire easily.. extension lead goes under garage door.
Is there a chance of screwing with the electronics doing it this way?
Ex. '99 996 C2 manual coupe.
sim996
PostPosted: Mon Feb 25, 2019 8:22 am    Post subject: Reply with quote
Maybe not on older cars, but in newer cars yes. The correct way is to connect to the battery positive and chassis earth. This way the car can sense the battery condition through the various electronics, otherwise they go haywire.
Littlered996
PostPosted: Mon Feb 25, 2019 8:25 am    Post subject: Reply with quote
Orient red.
Thanks for the battery thoughts. I’m still intrigued by the charging points in the engine bay. Presumably there’s a good reason why Porsche advises using them for jump starts and wonder whether the same applies to charging?
Simon
Paynewright
PostPosted: Mon Feb 25, 2019 8:50 am    Post subject: Reply with quote
Would it be feasible to rig up a solar charger at the garage? You can get kit for narrowboats to maintain battery charge whilst moored up.
Ian
cvega
PostPosted: Mon Feb 25, 2019 11:15 am    Post subject: Reply with quote
Ian
was about to suggest this, a 20-50W solar panel, cheap ish charge controller and ciggy adapter and you're good to go. amazon.
Someone here has done this in their garage, can't quite remember who:(
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Feb 25, 2019 11:51 am    Post subject: Reply with quote
I would disconnect the battery and run a solar charger to keep it topped off.
Get a quick disconnect thing in case you forget a 10mm spanner.
Magic919
PostPosted: Mon Feb 25, 2019 1:00 pm    Post subject: Reply with quote
cvega wrote:
Ian
Dammit?
997.2 C2S PDK
997.2 C4S PDK
pzero
PostPosted: Mon Feb 25, 2019 3:40 pm    Post subject: Reply with quote
Magic919 wrote:
cvega wrote:
Ian
Dammit?
No need to exclaim!
http://www.911uk.com/viewtopic.php?t=104190&postdays=0&postorder=asc&start=0
991.1 Carrera GTS
Littlered996
PostPosted: Mon Feb 25, 2019 6:22 pm    Post subject: Reply with quote
I have a solar panel rigged up from garage door (south facing, unobstructed), in through passenger window and into diagnostic socket. Battery still drains every couple of weeks, esp in winter. New battery and Portiacraft have confirmed it’s good and no drain. I can usually jump it with a jump starter (except for the time the boot and frunk refused to open...) but the whole thing’s a monumental pain in the backside and means I dread going to start it, rather than relishing it as I should.
I like the suggestion of combining solar trickle with battery cut off. Perhaps use my new toy to do a full recondition, then try that.
S
wasz
PostPosted: Mon Feb 25, 2019 6:48 pm    Post subject: Reply with quote
If you pop the hood, use a screwdriver to actuate the catch, then lock the car and then disconnect the battery the car will be locked too.
You can then disconnect the battery, hook the solar trickle charger up and let the hood down gently
Use something like this:
Just remember to "pop" the hood before you close it when driving off.....
EDIT: actually that might result in the alarm going off? I think my alarm battery is dead thats why I can do the above.
asterix_the_gaul
PostPosted: Mon Feb 25, 2019 7:32 pm    Post subject: Reply with quote
Yes, difficult in that situation, when I was there I've run the charger out over the pavement and put a piece of offcut carpet over it to stop the trip Hazard and also tried the solar panel on the roof trick but encountered the low winter sun issue too. Battery disconnect link is really the best answer and take a decent charged jump pack in case. I found myself forever jumping off the car I drove over to the garage in then leaving it running filling with fuel etc so less than ideal if you don't use it every weekend without fail.
