996 : 1997-2005 29
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Stever845
2005 Porsche 997 Carrera 2S
PostPosted: Sun Feb 24, 2019 7:17 pm    Post subject: New Condensers Reply with quote
I finally got round to removing my front bumper today to remove the condensers ready for replacement which was simple enough.Should any liquid have come out , I knew they were leaking and just thought there would be some sort of residue but nothing .
My cooling radiators don't look to healthy either i'm wondering should i replace these whilst in there.
Any thoughts and tips appreciated.
997.1 C2S Atlas Grey,Manual,sport chrono,pasm,
Mini Cooper S JCW
Ducati Panigale 1199S
 Filesize:  313.47 KB
 Viewed:  555 Time(s)
 Filesize:  458.04 KB
 Viewed:  555 Time(s)
GMG
PostPosted: Sun Feb 24, 2019 7:22 pm    Post subject: Reply with quote
...Just completed the same job;water radiators in similar condition but left them because car keeps temperature and they have an easier life being protected by the condensers...also because your system is open to atmosphere you should change the drier as well...oh and replace the o rings for new...
GMG
PostPosted: Sun Feb 24, 2019 7:24 pm    Post subject: Reply with quote
...one final thing; I purchased some PAG oil and coated the new o rings and assembly joints with it prior to reassembling....
Stever845
PostPosted: Sun Feb 24, 2019 7:25 pm    Post subject: Reply with quote
Yeh new o rings ordered defo and i was wondering about the drier so great stuff i will order one.
Im gonna put mesh on the bumper aswell thumbsup
Mini Cooper S JCW
PostPosted: Sun Feb 24, 2019 7:30 pm    Post subject: Reply with quote
GMG is spot on .. replace the dryer if the system is left open to atmosphere .
You wont get liquid out .. a tiny amount of oil is possible but none wouldn,t worry me .. make sure you add 30 - 40 mls of pag oil when its regassed for the replacement condensors .
Rads look fine .. if no obvious leaks then the next thing you look for is a pink chalky substance around the base .. this would be old antifreeze .. if nothing then dont replace imho .
Tobyone
PostPosted: Sun Feb 24, 2019 7:31 pm    Post subject: Reply with quote
Now isn't that a coincidence as I have has these replaced under warranty on my Gen 1 c4s
997.1 C4s GT Silver, factory Aerokit
Stever845
PostPosted: Sun Feb 24, 2019 7:35 pm    Post subject: Reply with quote
Should i just add the Pag oil on reassembly or get the re gas boys to do it . Obviously i will put it on the o rings etc'
Where does the drier live .
Mini Cooper S JCW
GMG
...only because I followed your helpful advice Iain Very Happy
PostPosted: Sun Feb 24, 2019 8:28 pm    Post subject: Reply with quote
A/c post ive only just done .. there is a very obvious picture of the dryer there ..
http://911uk.com/viewtopic.php?p=1463074#1463074
Get the guys regassing to refill the oil ive specified ... i would go with 40 mils plus 10 of dye .
1 CM3 = 1 Mil .
Stever845
PostPosted: Sun Feb 24, 2019 8:51 pm    Post subject: Reply with quote
Thanks Iain,
superb write up aswell.
Thanks Also GMG.
You guys just saved me a Couple of hundred quid thumbsup
Mini Cooper S JCW
