964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
996 Porkster
PostPosted: Sun Feb 24, 2019 6:22 pm    Post subject: 996 PSE exhaust replacement Reply with quote
Hey all. Not long into the ownership of a 2003 carrera 2 (3 weeks). It has the PSE exhaust and Just had the car serviced at HP Motorsport in Essex and been told the seams in the rear boxes have split. I've heard that the Top Gear exhaust is a good replacement for the PSE boxes as you can wire it up to the existing dash mounted switch. I've also seen this Spyder Performance exhaust and just wondered whether any of you guys have any experience with this system and what noise is like compered to the standard PSE system. Any comments on the quality of the exhaust would also be welcome.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2...
There's also a designtek exhaust from Design911, but would be grateful for your advice /opinions on a replacement for the PSE exhaust
Many thanks
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Sun Feb 24, 2019 7:00 pm    Post subject: Reply with quote
If the seams have gone it’s possible they could be repaired- give this guy a call. Others on the site have used his services.
https://www.exhaustmods.co.uk/porsche-911-996-977
Tim996c4
PostPosted: Sun Feb 24, 2019 8:03 pm    Post subject: Reply with quote
Had similar problems with my pse (also corroded tube on one side). Went for the Top Gear switchable system with 200 cell cats. Took a trip to Bridport for TG to fit it, and they connected the valve system to the existing switch.
The noise is pretty brutal on loud when you give it some gas Very Happy
Quiet is considerably less noisy, but I rarely use it in quiet as the noise is addictive on loud.
paulstevens64
PostPosted: Sun Feb 24, 2019 8:06 pm    Post subject: Reply with quote
Hi I had PSE on my C4S, and replaced with Top Gear. They are slightly louder in "off" mode, and 30-40% louder in "on" mode.
The noise in Loud, is not quite as rich as the PSE, but overall I think it is great.
If your seams can be welded, I would go for that and budget for a set of TG in a few years.
Paul
PostPosted: Sun Feb 24, 2019 9:31 pm    Post subject: Reply with quote
Devil
996 Porkster
PostPosted: Sun Feb 24, 2019 10:13 pm    Post subject: Reply with quote
Thanks guys. I think I'll give PCW a ring about getting the seams welded while I save up for the Top Gear exhaust. Nobody had any experience with the Spyder Performance exhaust I guess?
PostPosted: Sun Feb 24, 2019 10:18 pm    Post subject: Reply with quote
PC PC PC PC
I meant Welcome
Pmac32
PostPosted: Sun Feb 24, 2019 10:24 pm    Post subject: Reply with quote
I had a pse on my C4S which needed replacing. I looked at all the different options available and spoke to people about the options available. I didn’t want anything too loud and definitely didn’t want anything that droned.
I wanted a pse but made the mistake of purchasing a Kline system with 200 cel cats. In my opinion it’s ruined the car. Not a patch on the sound of pse and the drone you get between 2000/3000 rpm is bloody awful, it hurts your ears. I’ve had the car ten years and thought I’d keep it forever but it’s ruined my enjoyment of the car. I’ll never purchase an aftermarket exhaust again. I’d stick with a pse.
Lukec4s
PostPosted: Sun Feb 24, 2019 11:17 pm    Post subject: Reply with quote
I have a spyder performance switchable system. Stock cats. The system switches using a remote. It defaults to valves open so I rarely use the fob. I find valves open gives a nice sound, no drone and considerably cheaper than pse.
I have come across posts where people have diy’d the original pse button to operate aftermarket systems.
All in all no complaints. I’m considering sports cats to increase sound
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Mon Feb 25, 2019 11:11 pm    Post subject: Reply with quote
It's the addition of 200cell cats that make the sound offensive, if you have standard back boxes it's OK, if you have sports back boxes it's usually too much. At least having switchable boxes you can select the least offensive sound when required.
I have 200cell and pse. It's a bit stupid on full loud.
Shaoxter
PostPosted: Tue Feb 26, 2019 3:51 pm    Post subject: Reply with quote
I went for the Carnewal option, sounds as good if not better than the PSE it replaced (same issue as yours). You won't be eligible for a swap as yours are split, but call up Gert and see what he has in stock.
It's not switchable but that doesn't really matter as it's not intrusive or droney when driving gently.
M96
PostPosted: Wed Feb 27, 2019 7:48 pm    Post subject: Reply with quote
Having had TG 200 cell cats and switchable back boxes for nearly a year, I agree with the comments made already.
Horses for courses, and everyone has differing thresholds on noise, but the loud setting is too much for me (particularly on a vanilla C2), so has been used for all of about 2 miles in that year. Having said that I am happy with the quiet mode, and the option is always fun if you fancy scaring some folk...!
Also agree, while the TG Sound is good, it’s not quite so sophisticated / rich as the PSE equipped cars i’ve Heard over the years. Wouldn’t let that put you off though - especially with the price differential...
Having not noticed any perceivable performance benefit, I would just do switchable boxes first, then cats as a stage 2 for a bit more if I did it again, as there is little extra cost in a staged approach.
PostPosted: Wed Feb 27, 2019 7:59 pm    Post subject: Reply with quote
M96 makes a very good point and as much as exhaust note is a very personal thing its also important to consider what your putting it on and super sound or full sports boxes may be ok on a loud and lairy car with wings, lowered and things but if your ride is a stock car in a mild colour then maybe the mild sports options would suit the car better than a gates of hell opening exhaust. Thumb topgear do both mild and loud options Thumb and dont forget forum members get 10% discount as Topgear are a site sponsor Grin Thumb
996 Porkster
PostPosted: Wed Feb 27, 2019 10:20 pm    Post subject: Reply with quote
Although I've only had the C2 for just over 3 weeks, I absolutely love the sound of the PSE. There doesn't appear to be any aftermarket systems that offer the same or similar sound. As before, I think I'll get the seams welded for now and look into a TG switchable system later down the line.
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Thu Feb 28, 2019 5:11 pm    Post subject: Reply with quote
I was close to going for these boxes until I heard that the default is loud.. so every time you start the car it’s on loud, right?
I need stealth mode on startup to creep away from the house st unsociable hours.
Ex. '99 996 C2 manual coupe.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Feb 28, 2019 5:41 pm    Post subject: Reply with quote
The vacuum reservoir holds vacuum for a fair time, so possible to switch the exhaust before starting the car.
Mookin
PostPosted: Thu Feb 28, 2019 7:24 pm    Post subject: Reply with quote
I had my factory PSE replaced with Designtek Valvetronic back boxes. Came with a key fob system but my garage said was easy enough to wire up to the existing dash switch. Works perfectly, sounds blinking great. A great toy to play with. Very Happy
Ocean Blue Metallic Porsche 996, 3.4, Carerra 2, Manual, PSE, 2000.
TurboRob
PostPosted: Sat Mar 02, 2019 6:53 pm    Post subject: Reply with quote
Exactly same scenario for me - 1 week into a C2 with PSE and loving the sound (they're stuck on loud). Although mine look like they've been welded before - expecting to need to change them sometime soon.
Looks like the TG switchable system is the best route?
Lukec4s
PostPosted: Sat Mar 02, 2019 11:35 pm    Post subject: Reply with quote
Lukec4s
PostPosted: Sat Mar 02, 2019 11:38 pm    Post subject: Reply with quote
I meant to add comment to the above. The default of loud is not bad at all on the 911 at idle. I have the same early start. 6am. My previous e93 m3 with back box mod was so loud on cold start I would cringe 😂
