964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Lukec4s
PostPosted: Fri Feb 22, 2019 3:07 pm    Post subject: Fuel cap Reply with quote
Hi all
I just found that my fuel cover doesn’t lock. A quick look and I realised the small plastic part on the lid is missing. Does anyone know what his part is called or where I can get one. Hopefully the pic has uploaded
 Filesize:  1.49 MB
 Viewed:  591 Time(s)
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Feb 22, 2019 3:12 pm    Post subject: Reply with quote
996 201 423 00 Cap
I would try your nearest OPC
Lukec4s
PostPosted: Fri Feb 22, 2019 3:20 pm    Post subject: Reply with quote
Thanks for speedy response I’ll give them a call
Lukec4s
PostPosted: Fri Feb 22, 2019 3:59 pm    Post subject: Reply with quote
Sorted only £1.30 ... and there’s I was with my trousers down by my ankles waiting for the price.
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Sat Feb 23, 2019 11:31 am    Post subject: Reply with quote
While on the subject of fuel lids ...
Mine is a bit floppy!
I need to hold it open while fuelling, is there a part I can get to sort this, without changing the lid?
Thanks!
Ex. '99 996 C2 manual coupe.
PostPosted: Sat Feb 23, 2019 11:46 am    Post subject: Reply with quote
Thanks!
Yes, there is a spring that often gets lost. An OPC should supply. It won't cost much.
Halcyon
PostPosted: Sat Feb 23, 2019 5:03 pm    Post subject: Reply with quote
when I got my car, the fuel door wouldn't lock. so i bought a new actuator..
I set about fitting it and found that the rod had simply fallen off the old (working!) actuator frustrated
it has like a "check cable" to stop it falling off completely.
I re-fitted it. It's been fine since (nearly 3 years)
It's as fiddly as hell in there mind... You don't have much room!
996.2 Carrera 4 Convertible Tip
ballcock
PostPosted: Sat Feb 23, 2019 5:43 pm    Post subject: Reply with quote
Will investigate thanks!
