996 : 1997-2005 29
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Maxamplitude
PostPosted: Fri Feb 22, 2019 1:25 pm    Post subject: Buying a 911 997, IMS Help Reply with quote
Guys looking at purchasing a 911 997 C2 registered Sept 2005, Is there any way of knowing for sure which IMS bearing it has?
The engine number is 68515141
Thanks in advance
Max
PostPosted: Fri Feb 22, 2019 1:52 pm    Post subject: Reply with quote
That engine number is 15141 but it follows the design revision number 8.
Design revision 9 was the model that had the latest IMS modification that was done. The change over within that was at engine number 07475 for 3.6 litre cars.
Welcome to 911uk by the way.
PostPosted: Fri Feb 22, 2019 2:07 pm    Post subject: Reply with quote
Further to the above the engine number that you would ideally want is one ending 6-9-6-07475 or later.
6 denotes the 6 cylinder engine
9 is the revision number
6 is the model year so 2005/2006 cars
07475 or later = the cars with the latest IMS design
PostPosted: Fri Feb 22, 2019 2:30 pm    Post subject: Reply with quote
Welcome
Maxamplitude
PostPosted: Fri Feb 22, 2019 10:16 pm    Post subject: Oh No Reply with quote
Thanks guys its a 3.8 I planned to view but may wait until a later car becomes available, any idea what year of manufacture the 3.8 has the revised IMS?
Max
pzero
PostPosted: Fri Feb 22, 2019 10:26 pm    Post subject: Re: Oh No Reply with quote
Max
http://www.911uk.com/viewtopic.php?t=119108&sid=7d1a933ac0751eaa48bcbcab052a5ecf
991.1 Carrera GTS
PostPosted: Sat Feb 23, 2019 12:52 am    Post subject: Re: Buying a 911 997, IMS Help Reply with quote
If this is a 3.8 engine it has the latest IMS bearing.
The cross-over for the 'S' car was
6
8
5
0970
so
6
8
5
15141
would be ok. Thumb
PostPosted: Sat Feb 23, 2019 1:06 am    Post subject: Reply with quote
All irrelevant. If it goes pop I'll buy you a Turbo.
PostPosted: Sat Feb 23, 2019 1:29 am    Post subject: Reply with quote
I think others have posted the info but here it is just in case Thumb
Last IMS revision before no IMS (Gen2 MA1 block):
997 Carrera 3.6 with engine numbers from M96/0569507475 are the new IMS design.
M96/05 = 997 3.6 Carrera NA
6 = 6 cylinders
9 = design revision
5 = year (2005)
07475 = cumulative production serial
This means some MY2005 benefit and all MY2006 onwards benefit.
997 Carrera S 3.8 with engine numbers from M97/0168509790 are the new IMS design.
M97/01 = 997 3.8 Carrera NA
6 = 6 cylinders
8 = design revision
5 = year (2005)
09790 = cumulative production serial
Jake911
PostPosted: Sun Feb 24, 2019 12:16 pm    Post subject: Re: Buying a 911 997, IMS Help Reply with quote
Great info - Thx for posting
Basalt911
PostPosted: Wed Mar 06, 2019 6:08 pm    Post subject: Reply with quote
argh, for some reason I misread the engine number previously and smugly told myself that mine had the newer IMS
looking again, I realise it hasn't, so I'm back to reminding myself about the options for those of us that are 'less endowed' in the IMS department
at 93k miles, with a healthy clutch, and a magnetic sump plug (which is examined annually and shows no swarf at service) what would the considered wisdom advise?
stick or twist?
villaman
PostPosted: Fri Mar 08, 2019 4:34 pm    Post subject: Reply with quote
6 = 6 cylinders
9 = design revision
5 = year (2005)
6 = 6 cylinders
8 = design revision
5 = year (2005)
Hi Phil,
So if I may please confirm for the avoidance of doubt,
The below engine (3.6) number would have the later and larger IMS ?
69508806
PostPosted: Fri Mar 08, 2019 4:44 pm    Post subject: Reply with quote
695 08806 is after 695 07475 so will have the latest IMS bearing.
villaman
PostPosted: Fri Mar 08, 2019 5:30 pm    Post subject: Reply with quote
Thanks T8
PostPosted: Fri Mar 08, 2019 7:21 pm    Post subject: Reply with quote
Sorry Viilaman I am a bit late relying but looks like Terry has confirmed for you its the newer better IMS Thumb Thumb
PostPosted: Fri Mar 08, 2019 7:25 pm    Post subject: Reply with quote
stick or twist?
If it hasn't gone bang in 93,000 miles and your doing the correct risk reducing maintenance drive it and enjoy it :thumb:and dont mess with whats not broke , seems to be the general advise given at that mileage
villaman
PostPosted: Fri Mar 08, 2019 7:31 pm    Post subject: Reply with quote
Thank you Phil
It seemed a fairly simple math ...but just wanted to make sure....
resigner
PostPosted: Fri Mar 08, 2019 7:43 pm    Post subject: Reply with quote
stick or twist?
Or it's already been changed, which at 93,000 miles I would of thought it had been, as it must of had at least 1 new clutch by now......
Now, OP, you said "Guys looking at purchasing a 911 997 C2" and that would be a 3.6 litre car, because a 3.8 would be a C2S..........
PostPosted: Sat Mar 09, 2019 12:36 pm    Post subject: Reply with quote
The OP (maxamplitude) later corrected himself and confirmed it was an S he was looking to view.
He has since bought it.
See --> http://911uk.com/viewtopic.php?t=132591&start=0&postdays=0&postorder=asc&highlight=
Jake911
PostPosted: Sat Mar 09, 2019 4:41 pm    Post subject: Reply with quote
stick or twist?
I have a lovely 997.1 that would be considered 'at risk' given the older IMS bearing. The bores were checked and all is good. I never go above 3000 rpm until the oil is at 90 or above. I have just gone over 30,000 miles and I have no concern or worries. I have annual oil changes with an annual mileage of around 4000 per yer year. Its often been said that this issue affects less the 5% of cars. Do your due diligence, maintenance and enjoy.
