Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
PostPosted: Thu Feb 21, 2019 11:43 pm    Post subject: Door Sill Kick Panel -------------- Reply with quote
Hi all, has anyone seen these illuminating Sill Kick Panels before, ive heard of them but not sure where i could get them, are they original or after market items? Arw they expensive?
J
 Filesize:  58.36 KB
 Viewed:  867 Time(s)
PostPosted: Fri Feb 22, 2019 4:33 am    Post subject: Reply with quote
I am sure someone on here put his name or his mum's name on one a few months back Confused
Will have a search for you Thumb
pzero
PostPosted: Fri Feb 22, 2019 6:44 am    Post subject: Re: Door Sill Kick Panel -------------- Reply with quote
J
http://www.911uk.com/viewtopic.php?t=125262&sid=6a0173b8744a0ca001f3a320ad10b2d3
Confused
991.1 Carrera GTS
PostPosted: Fri Feb 22, 2019 2:38 pm    Post subject: Reply with quote
frustrated
I was searching for about an hour last night for that thread wack
pzero
PostPosted: Fri Feb 22, 2019 3:16 pm    Post subject: Reply with quote
HSC911 wrote:
frustrated
I generally use Google when searching for anything on the forum.
In this case I put in;
911uk illuminated door sills
The first thread thrown up was the one I used.
991.1 Carrera GTS
New997buyer
PostPosted: Fri Feb 22, 2019 5:18 pm    Post subject: Reply with quote
Top tip thumbsup
PostPosted: Fri Feb 22, 2019 5:59 pm    Post subject: Reply with quote
The OE ones are not cheap
https://www.design911.co.uk/fu/prod13624/Side-Sills-Trims-in-Stainless-Steel-with-Logo--Illuminated-Porsche-997-MKI---997-MKII/
but as said there are aftermarket options discussed in the thread further up. Thumb
Gottans
PostPosted: Sun Feb 24, 2019 8:23 am    Post subject: Reply with quote
Agree with the not cheap and apparently self destruct when removed. I didn't find any second hand oem illuminated trims when mine needed replacing.
