964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
cbriggs1978
PostPosted: Wed Feb 20, 2019 9:54 pm    Post subject: Targa windscreen replacement Reply with quote
Evening, it looks like I will have to bite the bullet and get my windscreen changed on my 2002 Targa as the chip (that has been previously repaired) has a crack propogating from it - 3mm at the moment but I am sure will grow.
Any pitfalls I need to be wary of - or just ring the insurance and not worry? Is it a model specific screen or same as a convertible or coupe?
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Wed Feb 20, 2019 11:36 pm    Post subject: Reply with quote
I got mine replaced a few years ago but I don't remember if it was the same as Coupe or not?
I just rang my local windscreen place, told them my insurer and explained that I wanted an experienced (at Porsche) fitter and they fitted a genuine screen for me too.
PostPosted: Thu Feb 21, 2019 8:22 pm    Post subject: Reply with quote
Make sure they know the gps antenna is fitted to the scuttle panel n/s/f .. so many of these guys pull it off then realise there is a wire there .. it WILL break it .. you WILL need a new wiring cable and a gps antenna .
Most common cause of nav failure .. ive just had a windscreen fitted and ..
Only applicable if you have nav though .
cbriggs1978
PostPosted: Fri Feb 22, 2019 6:44 am    Post subject: Reply with quote
Thanks, the car has nav but I have put in single din aftermarket so I could do the centre console delete but I will point it out as it may get put back to original by a future owner! Thanks for the tip
