991 : 2011- 19
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Pretzel
PostPosted: Tue Feb 19, 2019 7:30 pm    Post subject: Exhaust tips - how close to rear PU bumper Reply with quote
After replacing the engine mountings (narrow body C2) exhaust tips are now touching the rear PU bumper valence.
So, how much of a gap do I need to leave to avoid heat damage to the PU?
There seems to be a fine balance between providing adequate clearance and the exhaust tip appearing to point down which doesn't look right.
993 C2 Aventura
PostPosted: Tue Feb 19, 2019 7:32 pm    Post subject: Reply with quote
Won't do any damage apart from maybe wear the paint off as they don't get hot enough (not on a 996 anyway). Rule of thumb, I always say enough to get your little pinky inbetween.
Endoman
PostPosted: Tue Feb 19, 2019 8:34 pm    Post subject: Reply with quote
I reckon 5mm, you could modify the w/b shield or fabricate something. They will melt the pu if they touch. I put a 5mm spacer on the engine mounts to drop the engine a bit. RS mounts with extra RS spacer. I spent ages getting the wide oval tips just where I wanted them even to the extent of trimmimg a bit off the silencer hanger hook.
A tail pipe fell off mine and the exhaust gases melted the pu so badly I had to replace it.
Allan E
PostPosted: Tue Feb 19, 2019 9:38 pm    Post subject: Reply with quote
The gap on my car is approx 20mm, the exhausts are the originals as are the tips so I am assuming the gap is as standard.
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
 Filesize:  1.69 MB
 Viewed:  1450 Time(s)
decgraham
PostPosted: Wed Feb 20, 2019 7:28 am    Post subject: Reply with quote
Here's a pic of how mine sit. Thumb
ATB Smile
 Filesize:  283.24 KB
 Viewed:  1394 Time(s)
PostPosted: Wed Feb 20, 2019 7:54 am    Post subject: Reply with quote
It's all dependant on how much your engine mounts have sagged. Are they new?
NIBrown
PostPosted: Wed Feb 20, 2019 7:58 am    Post subject: Reply with quote
Agreed that engine mounts will play a large part on how the tips sit.
I changed my mounts for C4 as the old oil-filled ones weren't at their best, had to make quite large adjustments to the tips as they were touching.
993S with 62K now sold :-(
MK7 Golf R, SLK 300,
Skoda Yeti 140TDi 4x4 with 152K Smile
Previous
Mk5 Gti Pirelli Edition, Audi TT diesel, Defender 300Tdi CSW,90 Tomb Raider, Golf 7R, 993S
Mk6 Golf GTD, Mk5/4/3 Golf Gti, Audi S3
View user's profile Send private message Send e-mail Yahoo Messenger
Cameltoe & Heel
PostPosted: Wed Feb 20, 2019 8:31 am    Post subject: Reply with quote
I've pretty much replaced everything, inc C4 mounts, mufflers and hangers, and still able to centralise, you should too. It would do my noggin in if I couldn't get a decent gap.
What engine mounts did you use and what tips you got?, big ovals are obviously bigger and therefore not as much gap.
Trev
Last edited by Cameltoe & Heel on Wed Feb 20, 2019 11:08 am; edited 1 time in total
Tobesetc
PostPosted: Wed Feb 20, 2019 9:46 am    Post subject: Reply with quote
Pic from slightly lower angle than would be perfect...
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
 Filesize:  219.27 KB
 Viewed:  1332 Time(s)
Pretzel
PostPosted: Wed Feb 20, 2019 7:44 pm    Post subject: Reply with quote
Thanks everyone for your replies, very useful especially the photos.
Exhaust tips were on the car when I purchased it, they look like big ovals or similar and were a nice fit before fitting the new engine mounts (genuine OPC C4 mounts)
Current gap is even all round about 20mm but doesn't look quite right so I will try adjusting them again, reducing the gap taking into account your comments.
I would be interested in seeing a side shot taken low down if anyone has one available.
993 C2 Aventura
decgraham
PostPosted: Thu Feb 21, 2019 10:04 am    Post subject: Reply with quote
Here you go, hope this is what you are looking for Thumb
Oh my engine sits on C4 mounts.
ATB Smile
 Filesize:  72.73 KB
 Viewed:  1189 Time(s)
Endoman
PostPosted: Thu Feb 21, 2019 11:50 am    Post subject: Reply with quote
Porsche wide ovals, circumferencial clearance 15mm . On full Fabspeed system. Please excuse finger prints. No oil drips Very Happy
 Filesize:  176.8 KB
 Viewed:  1161 Time(s)
 Filesize:  119.88 KB
 Filesize:  119.43 KB
PostPosted: Thu Feb 21, 2019 12:15 pm    Post subject: Reply with quote
alex yates wrote:
Won't do any damage apart from maybe wear the paint off as they don't get hot enough (not on a 996 anyway). ...........
Hand what a perfect opportunity for a kettle comment Wink
