991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Oilline
PostPosted: Tue Jul 02, 2019 8:19 am    Post subject: Reply with quote
So after my fan refurb the car went straight off to the paint shop for some tidying up.
I therefore did not realise my alternator was not charging my battery. The battery light is not coming on but checking the voltage at the battery with the engine running im only seeing 12v.
So i need to whip the alternator off and see if i also have got my wires crossed!
Or could it be a faulty voltage regulator which i fitted? Its marked up as a Beru part bit it was very cheap off the internet. You do hear of fake components being sold.
So to clarify, the blue wire goes to the insulated terminal and the brown wire to the alternator chassis?
But shouldnt my battery warning light be on ??
Cameltoe & Heel
PostPosted: Tue Jul 02, 2019 10:08 am    Post subject: Reply with quote
Hi there, I had the same issue after my rebuild, the alternator not charging the battery. It's unlikely to be your new regulator, it's more likely to be the alternator itself.
I took mine to a local specialist and he diagnosed an issue with the rectifier, swapped it out for a new one, cost circa £100. Put it back in and all was well.
Mine did cause the battery light to illuminate however.
Trev
andyobro
PostPosted: Tue Jul 02, 2019 10:13 am    Post subject: Reply with quote
You are correct on which wire should be where, the wires on mine naturally sat the other way round when I fitted it, hence my mistake. I think the battery light was on when I had my wires crossed, but not 100% sure now.
Edit, just reread my post when I made the mistake, I think I would have mentioned the battery light, so I don't think it cam on with the wires swapped, but not 100% sure, sorry i can't be definite on that point.
993 Carrera
www.instagram.com/993andy
Kat1
PostPosted: Tue Jul 02, 2019 10:57 am    Post subject: Reply with quote
Do these pics help?
Oilline
PostPosted: Wed Jul 03, 2019 6:47 am    Post subject: Reply with quote
So was my own stupid fault. Found the 8mm nut securing the main power lead rattling around inside the plastic end cap ! I mustn’t of tightened it up when I put it back together after doing the fan.
Charging now but only 13v on tick over. I have a single pull conversion so alternator running slower than standard so maybe that’s why ?
andyobro
PostPosted: Wed Jul 03, 2019 12:01 pm    Post subject: Reply with quote
Ya wally Smile I have single pulley conversion too, I haven't checked to see what it charges at at idle, I may get chance tonight.
993 Carrera
kingroon
PostPosted: Wed Sep 04, 2019 10:41 am    Post subject: Reply with quote
Thread Dig.. bye
I am about to have my Fan repainted - do I go with Powder Coating it..?
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
Endoman
PostPosted: Thu Sep 05, 2019 12:11 am    Post subject: Reply with quote
Some say don't, unless you take it somewhere that is used to doing magnesium. Loads of threads on it just to add to the confusion.
kingroon
PostPosted: Thu Sep 05, 2019 8:01 am    Post subject: Reply with quote
So is the Fan [as well as the Shroud] Magnesium too..?
Hasta Luego..
KingRoon
AP90
PostPosted: Thu Sep 05, 2019 8:18 am    Post subject: Reply with quote
Hi
Have a look at my post on page 1 of this thread to see my experiences with powder coating
I now have paint on a new fan and no problems so far
kingroon
PostPosted: Thu Sep 12, 2019 4:00 pm    Post subject: Reply with quote
Yes AP90, I read and saw that..
I have just heard back from Tactical Coatings UK Ltd. and my Shroud has been Cerakote coated.. Cool I really want to post the photo Chris there sent me, but I am going to wait until I have it in my hands and then take a [better!] photo of it.. But it looks awesome.. Razz
Just need to sort where, what and how I get the Fan painted..
I'm kinda moving away from the Powder Coating route..! Seems a little worrisome..?
Hasta Luego..
KingRoon
Diddi
PostPosted: Thu Sep 12, 2019 5:49 pm    Post subject: Reply with quote
It looks great, but........the fan coating gives a lot of unbalance and vibrations, I just coated the housing and polished the fan.
Grüsse, Diddi
 Filesize:  817.77 KB
 Viewed:  485 Time(s)
kingroon
PostPosted: Fri Sep 13, 2019 8:29 am    Post subject: Reply with quote
Diddi wrote:
.. and polished the fan.
Could you post a photo of the Fan please..?
Hasta Luego..
KingRoon
Diddi
PostPosted: Fri Sep 13, 2019 11:04 am    Post subject: Reply with quote
.......only polished ! no vibrations and the bearing does not cause any probs - okay, colored looks better - when the hood is open!! Hand
Grüsse, Diddi
 Filesize:  135.74 KB
 Viewed:  418 Time(s)
kingroon
PostPosted: Fri Sep 13, 2019 12:19 pm    Post subject: Reply with quote
Love that Bare Naked look.. Cool
Corrosion an issue..?
Hasta Luego..
KingRoon
Diddi
PostPosted: Sun Sep 15, 2019 10:13 pm    Post subject: Reply with quote
.........if dirty clean & polish 1 time a year Thumb
Grüsse, Diddi
 Filesize:  70.54 KB
 Viewed:  296 Time(s)
PostPosted: Sun Sep 15, 2019 10:28 pm    Post subject: Reply with quote
A somewhat timely thread. After some 'pinging' and slight rough running of the trusty 964 at constant speed and lumpy idle I've diagnosed the distributor drive belt has just given up Rolling Eyes
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
kingroon
PostPosted: Mon Sep 16, 2019 8:20 am    Post subject: Reply with quote
I got the Shroud back from TAC Coatings [http://www.taccoatings.co.uk/contact/] and it looks GREAT..!
Trouble is now I really need to get the Fan done too, as it will really show up next to/inside the Shroud..
So.. Zermatt Silver..? Who do I send it to..??
I was kinda thinking about sending the Fan to TAC and getting them to Cerakote it a lighter Bronze.. It isn't exactly a smooth surface though, so wondering if it'll make a noise/wind resistant whizz when spun up..?
Hasta Luego..
KingRoon
 Filesize:  167.65 KB
 Viewed:  241 Time(s)
kingroon
PostPosted: Thu Sep 19, 2019 3:39 pm    Post subject: Reply with quote
Sad
Hasta Luego..
KingRoon
 Filesize:  76.51 KB
 Viewed:  160 Time(s)
 Filesize:  111.89 KB
 Viewed:  160 Time(s)
andyobro
PostPosted: Sat Sep 21, 2019 4:34 pm    Post subject: Reply with quote
kingroon wrote:
Sad
oh *****, saves getting it painted I guess..... New ones are less than I thought.
993 Carrera
Goto page Previous  1, 2
Page 2 of 2
