964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
tgdesign
2006 Porsche 997 Turbo
PostPosted: Tue Feb 19, 2019 10:52 am    Post subject: 991 GT3 wheels on 997 turbo will they fit??? Reply with quote
Hi Gents
I have a 997 turbo but I am looking to change the wheels too the ones off a 991 GT3 with center locks, the question is will they fit Question Question Question
Been center locks you can't use spacers well I don't think you can?
Has anyone on here done it or seen it done before, I know you will need 20" all round as 21" on the rear will mess the 4wd diff up.
Will the offsets work? will the front shocks hit the rim, will the arches need rolling?
Any input welcome.
Thumb Thumb Thumb
 Filesize:  53.49 KB
 Viewed:  624 Time(s)
Gazc2
PostPosted: Tue Feb 19, 2019 11:23 am    Post subject: Reply with quote
I would pop over to Rennlist and 6speedonline and ask as well pretty sure I have seen a set on a turbo before not sure about the ride and the fit though.
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Feb 19, 2019 7:05 pm    Post subject: Reply with quote
As you're asking, I assume you've already spent on the cl hubs?
Or, if not, I'd check the cost of the parts (and labour if you're not DIY) before you buy the wheels.
Isysman did the cl conversion on his 997 GT2Rs
PostPosted: Tue Feb 19, 2019 9:15 pm    Post subject: Reply with quote
Hope you do it, would look so Cool
911TEL
2011 Porsche 997 Turbo S
PostPosted: Wed Feb 20, 2019 7:41 am    Post subject: Reply with quote
It would be advantageous to read Isysmans part of the thread where he changed his studhubs out for C/l hubs as this is not a straightforward job.
There are other considerations such as the offset (ET) which contributes to the clearance of rim/ suspension components.
Wheel diameter is also going to contribute as the rim size + rubber profile will be a fair bit different.
For a relatively quick bit of advice maybe a call to Centre Gravity or Chris at Exel wheels may guide you early so that you may get a quick idea if it’s worth going ahead ....or if you have the appetite for the change ....
997 Gen 2 Turbo S Basalt Black -BBS CHR, Kline inconel exhaust, DSC V1 & Polished Bliss air freshener...
SL 55 AMG Obsidian Black
Brompton S2L Black edition
911TEL
PostPosted: Wed Feb 20, 2019 7:56 am    Post subject: Reply with quote
