996 : 1997-2005 29
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
love154
PostPosted: Tue Feb 19, 2019 1:19 am    Post subject: pdk steering wheel change help Reply with quote
Hi i have a my2009 c4s and would like to change the steering wheel. i have the multi function at the mo.. have had a search in the forum but could not find what i was looking for. Can i fit a paddle wheel with multi function to my car. if so any body no how hard and expensive it is to do.
thanks
Myasinax
PostPosted: Tue Feb 19, 2019 6:30 am    Post subject: Reply with quote
Yes, you can fit the newer style paddleshift steering wheels, but it’s not completely straightforward. You will need a wiring loom adapter from a company called gpsadapter (https://gpsadapter.us).
I fit a 2015 Macan steering wheel to my 2010 C4S.
baldguy
PostPosted: Tue Feb 19, 2019 6:56 am    Post subject: Reply with quote
It depends.... if its a 2009 Gen 2 model its a straight swap if its a Gen 1 then you'll need an adapter as per above
Magic919
PostPosted: Tue Feb 19, 2019 5:48 pm    Post subject: Reply with quote
No, you need the adapter to fit the later wheels to a 997.2.
997.2 C2S PDK
997.2 C4S PDK
PostPosted: Tue Feb 19, 2019 6:19 pm    Post subject: Reply with quote
As others are saying the 997.2/991.1 sports wheel never came with MF so you must be wanting to fit the 991.2 later wheel with the MF and paddles , you will need the newer domed airbag, and the adapter from the guy in the USA in the link above.
forum member Nigel99 has done it so you could PM him with questions . I am sure other have but I have seen Nigels .
 Filesize:  52.04 KB
 Viewed:  944 Time(s)
love154
PostPosted: Tue Feb 19, 2019 10:55 pm    Post subject: Reply with quote
Sound expensive will I need to change the loom if I just go for paddles
Rhodris-dad
2015 Porsche 991 Carrera 4 GTS
PostPosted: Tue Feb 19, 2019 11:25 pm    Post subject: Reply with quote
About 18 mths ago I enquired about a 991 at an OPC that had thumb changers......they quoted £600 to retrofit a paddle wheel.
If you tackle it yourself....remember to disconnect the battery before you start (airbag).
2015 991.1 C4GTS PDK
2010 997 C4S PDK sold
2003 996 C2 Tip sold
318touring
PostPosted: Wed Feb 20, 2019 4:00 am    Post subject: Reply with quote
I've just done this - 45 mins for an independent Porsche garage to do the change for me. Obviously I lost MF on my steering wheel but hey paddling is much more fun than thumbing! I do on occasions try to use the non-existent volume control on my spaddle steering wheel. My son smirks everytime that happens. Old habits die hard.
500 quid for the 2nd hand steering wheel and 50 quid for the garage.
Myasinax
PostPosted: Wed Feb 20, 2019 6:22 am    Post subject: Reply with quote
No, if you just want the paddleshift steering wheel which was available with the 997 gen 2 as an extra, then you can swap over your airbag and install the steering wheel. This is assuming you have a gen 2 and also may need a device like the Foxconn or iCarsoft to disable the airbag light if it comes on.
I installed the MF paddleshift steering wheel and am very happy with the result, though there are a few items with the wheel that could cause an issue. If u decide do to go ahead with the MF change you can PM me.
love154
PostPosted: Wed Feb 20, 2019 2:24 pm    Post subject: Reply with quote
Thanks for that. what did it end up costing you to get it all done
PostPosted: Wed Feb 20, 2019 2:56 pm    Post subject: Reply with quote
Agreed if you just want the 997.2 991.1 sports wheel with paddles instead of the 997.2 wheel with rockers thats a very easy swap but that wheel didn't come with an MF option so you would lose that ,other than that its pretty much plug and play and will use the same round flat airbag , so you just need the wheel.
I swapped mine to the sport one but in manual. Thumb
 Filesize:  82 KB
 Viewed:  751 Time(s)
MJA911
2012 Porsche 991 Carrera
PostPosted: Wed Feb 20, 2019 3:52 pm    Post subject: Reply with quote
Was that on a 991.1? Asking because I have a MF wheel on mine and I’d rather paddle too, but apart from volume and phone control (which can also be done on the centre console) it has the thumbwheel that controls the menu and options in the instrument binnacle. I don’t see another way of controlling that without the thumb wheel? Apparently cars without an MF wheel have an extra stalk on the column and need an additional interface to convert to a paddle wheel. is that what you had to do?
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
Rhodris-dad
PostPosted: Wed Feb 20, 2019 4:14 pm    Post subject: Reply with quote
£600 was the price Chester OPC quoted on a 991.1 that I was looking at.
The reference I made with regards to the airbag was that I had replaced the indicator stalk assembly on a 996 and would be the same for any wheel change with an airbag.
Myasinax
PostPosted: Thu Feb 21, 2019 6:20 am    Post subject: Reply with quote
The steering wheel with the airbag was expensive and cost around £800 for a good quality used one. The loom with shipping came in at about £250.
New997buyer
PostPosted: Thu Feb 21, 2019 7:12 am    Post subject: Reply with quote
Where did you source your wheel from Phil? Question Thumb
