Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
toptime
PostPosted: Sat Feb 16, 2019 5:11 pm    Post subject: Trickle charge at 15.5v ? Reply with quote
Hi everyone,
I just noticed that my 07 C2 is trickle charging at 15.5v
The charger is an Aldi smart charger / conditioner which shows the charging voltage. I’ve been using it since the start of the winter and it has been working fine but I’m sure it was charging at less the 14v when I used it last.
I’m assuming the voltage is slightly higher as the current is now low as it trickle charges.
Anyone have any experience with this? Or maybe the same voltage on the same charger? Seems a bit high to me........
kurlykris
PostPosted: Sat Feb 16, 2019 6:12 pm    Post subject: Reply with quote
Can you check the voltage at the battery terminals with a digital Multimeter to verify the actual voltage ?
You`ll boil the battery at anything over 14.4v and it will be gassing nooo
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
toptime
PostPosted: Sat Feb 16, 2019 6:38 pm    Post subject: Reply with quote
Yes that was my concern Surprised
As soon as I unlock the car (and put a load on the battery) the charger display drops to 12.9v and I measure the same with the mm. If I switch the charger off the battery voltage is 12.7v which is fine.
Switch the charger back on and it shows 12.9v then rises back to 15.3v with 5 to 10 mins......
Weird.......
Something to do with surface charge maybe?
kurlykris
PostPosted: Sat Feb 16, 2019 7:02 pm    Post subject: Reply with quote
You`ll only see the surface charge after you have disconnected the charger, it should only be about 0.5v, I usually put a small load on the battery for 30 seconds or so, then leave it for an hour or 2 before I test the open circuit/actual voltage of the battery.
It sounds like the voltage regulator is fubarred in your battery tender to me nooo
toptime
PostPosted: Sat Feb 16, 2019 7:21 pm    Post subject: Reply with quote
Sounds like it’s time for a new charger then!
Ironically it’s sat at 13.7v for the last hour.!
PostPosted: Sat Feb 16, 2019 8:00 pm    Post subject: Reply with quote
If the charger is over chargeing the battery then the battery will be warm to the touch .. if a severe over charge then it will get hot and you will have an acrid smell .. it will make your eyes water .
Ive seen it .. battery was the shape of a balloon .. we couldnt go near the car for the smell and we pushed it outside to cool down .. full protective gear and we finally removed the battery once it had cooled down .. scary stuff !
That was an alternator fault pushing over 18 volts into it though .
997 and they can charge upto 16 volts .. its normally when a battery is very dead or a possible fault .. but at that voltage it doesnt seem to boil a battery .. close to the edge though in my books .
basically what im saying .. see how hot the battery is .. if cold then dont worry .. if its getting warm then the charger is faulty or the battery is .
IMHO anyways .
toptime
PostPosted: Sat Feb 16, 2019 8:19 pm    Post subject: Reply with quote
Thanks for the replies guys. Battery is not warm, no smell and no signs of anything untoward. If the charger didn’t have a readout I would have no reason. To think anything is wrong.
Really don’t want to risk cooking anything though so I think I’ll get another one.
Luddite
PostPosted: Mon Feb 18, 2019 12:32 am    Post subject: Reply with quote
OK, I have zero knowledge of gel batteries, and my info only really applies to lead acid batteries thus may be of little use here..
With the alternator charging the battery 13.2 volts and under too low 13.8v to 14.5 OK above 14.5v too high.
In the case of lead acid batteries, if charging or discharging heavily they give of EXPLOSIVE gas and if my poor memory is correct the gas is Hydrogen..? I have seen the aftermath of an accident where a battery exploded blinding an engineer in one eye as the result of the gas build up external to the battery being exposed to a flame.. though any kind of spark caused by disconnecting a charger lead crocodile clip before switching the charger off can cause an explosion if the battery is gassing, same goes for a loose clamping arrangement on one of the terminals and the ign key turned to start position...creating a spark at the terminals...
Battery fully charged taken off the charger and left disconnected from any circuit for approximately an hour and voltage readings taken across the battery terminals.
12.72 volts 100% efficient 12.52v 80% 12.3v 60% 12.12v 40% 11.9v 20%
Taking voltage measurements with the battery connected in the car can give readings that mislead given the demands of the circuits connected, often referred to as parasitic losses. A worst case scenario might be measuring across the battery terminals with the starter turning the engine over and not starting, where a reading of 10v to 10.6 might be considered average, though could be as low as perhaps 4v if the battery is on it`s last legs but still able to turn the engine over, all be it slowly..
No doubt this info is well out of date, but may just be of use to those with older Porsches running lead acid batteries...?
toptime
PostPosted: Mon Feb 18, 2019 7:10 am    Post subject: Reply with quote
So, I exchanged the charger for a new one yesterday. I checked the charger after about 6 hours and it was showing 13.7v. Checked again this morning and its back to 15.3v Question
The battery is a Bosch S5 and all appears well......
jl-c
PostPosted: Mon Feb 18, 2019 10:06 am    Post subject: Reply with quote
You don’t say what you replaced it with. Much as I like Aldi biscuits I would not trust my Porsche to an Aldi branded battery charger. Buy ( or borrow, I guess) a CTek. Totally your choice but not a road I would go down. Things are cheap for a reason...... Surprised
toptime
PostPosted: Mon Feb 18, 2019 11:15 am    Post subject: Reply with quote
I replaced it with like for like from Aldi. The Aldi / Lidl units get very good reviews and are used by owners on the premium car forums. It was the reviews that made me aware of them and so I picked one up to give it a try.
I also noticed on the back of the packaging of the new charger that the charging end voltage is between 15.1v and 15.5v so this answers my original question.
Thanks all for your help.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Feb 18, 2019 11:21 am    Post subject: Reply with quote
I don't know my people rate CTEK chargers so highly. They are certainly OK, but of the two trickle chargers I have ever had fail on me, both have been CTEK ones. They are generally OK, but certainly not 'fit and forget'.
jl-c
PostPosted: Mon Feb 18, 2019 11:26 am    Post subject: Reply with quote
Just speak as you find, you obviously fell unlucky. I have 4 CTek’s which are all in use most of the time (if not on a car, re-conditioning spare batteries) and have been absolutely faultless. ( so that should put the kiss of death on them! ) Floor
maph
PostPosted: Mon Feb 18, 2019 4:42 pm    Post subject: Reply with quote
OP, glad you are sorted Thumb
Regards C-tek my first charger stopped working with little use (mode button packed up, a common fault apparently) making it impossible to use.
I now have two newer C-tek MSX 5.0s, but I am not totally convinced with these either. I was charging one of my other cars in storage (BMW M Coupe) and it was all lit up with a full set of green lights, doing it's pulse stage apparently....... went to take it out and the battery was completely stuffed.
Reconnected it, put it in a restore mode, checked it a few days later, again all green lights, happy days....... no battery still dead.
New battery and has not skipped a beat since, just do not trust the c-tech's reporting any more, not so smart me thinks.
Again, I am probably unlucky but I agree that their reputation seems higher than the quality of their products.
2012 997.2 Turbo S - ES650
Oggie
PostPosted: Tue Feb 19, 2019 7:14 am    Post subject: Reply with quote
Charging at 15.5V isn't unusual for a "smart" or "multi-stage" charger. On some chargers (I'm not familiar with the Aldi charger) have a stage called equalisation which will charge at a higher voltage of between 15V and 16V for a period to reduce sulphation and stir up the electrolyte to stop stratification that can occur in wet type lead-acid batteries.
For more info, there is an article on the charging stages here: http://www.chargingchargers.com/tutorials/charging.html
'02 996 Carrera Cabriolet
'99 986 Boxster
