964 : 1989-1993 6
Boxster : 1997- 17
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
toddy2
PostPosted: Sat Feb 16, 2019 4:54 pm    Post subject: (Updated)996 Mayo, noise, oil leak - should I be worried.... Reply with quote
Not having much luck with cars at the moment. Wifey's range rover blew both turbos last week and we're having these replaced (22hrs labour!). So in the meantime she's using my 9964S for the school run etc. lots of short journeys.
After being out today she reports that she heard a 'noise'. Great I thought Evil or Very Mad I couldn't hear anything, but spotted it has recently started leaking oil, there was a small patch from the day before and the oil level is low (still in the limits). Mayo in the cap, I put his down to the short journeys. What concerns me is the oil splattering on the bumper. Should I be concerned. Coolant seems ok.
I've told her not to touch it and I'm booking it in for a service and check over.
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
 Filesize:  758.74 KB
 Viewed:  1371 Time(s)
 Filesize:  732.42 KB
 Filesize:  693.59 KB
alex yates
PostPosted: Sat Feb 16, 2019 5:10 pm    Post subject: Reply with quote
Wash your car, clean that mayo out and top your oil level up to where it should be then check again after your next drive.
toddy2
PostPosted: Sat Feb 16, 2019 5:18 pm    Post subject: Reply with quote
Good shout, I'll give that a go. Any suggestions on the best way to clean out the mayo. I just seem to push it further in when I use a cloth and my fat fingers don't fit.
1968 911T
2002 996 4s
1988 944 (Sold)
77szymon
2003 Porsche 996 Carrera 4S
PostPosted: Sat Feb 16, 2019 5:19 pm    Post subject: Reply with quote
I have similar mayo on my bmw bad AOS was to blame, but also I'm dealing now with oil cooler and these could go bad too very common been told could be reason for mayo..? can you see from where oil is leaking?
2003 Porsche 911 996 c4s
1988 BMW 635csi Highline - waiting for full restoration
1999 BMW e36 328i Cabrio - still not finished project.....
2011 Mercedes S350L
2004 Audi a2 1.4 tdi - I can't stress enough how good these cars are
2012 Mercedes C220 cdi Estate AMG Sport Plus Pack - wife
toddy2
PostPosted: Sat Feb 16, 2019 5:56 pm    Post subject: Reply with quote
Thanks, can't see where it's leaking. I've left a board underneath tonight
1968 911T
2002 996 4s
1988 944 (Sold)
PostPosted: Sat Feb 16, 2019 7:17 pm    Post subject: Reply with quote
The Mayo is caused by moisture and heat .. water condensation in the pipe due to temp differences basically .
Im not sure why some cars get it and others dont .. different useage i guess .
clean out the cap but dont worry too much .. in the great scheme of things its a tiny amount compaired to the amount oil in these .. maybe a spoon or something similar to get some of it out of the tube .
Headgeasket , water in the oil .. you would have other symptoms .. white smoke out the exhaust .. misfires .. possibly oil in the coolant .. etc etc ... so i dont think its bad atm.
The residue on the bumper / pu is interesting though .. i would stick my head underneath the car and have a look .. any obvious oil leaks .. it looks like something is blowing back from under the car .. oil .. maybe .
It might also just be condensation from the exhaust .. cats do produce water as a by product after all .
Basically .. go with what Alex first said .. clean the rear end .. maybe have a look under the car and monitor it .
toddy2
PostPosted: Sat Feb 16, 2019 7:34 pm    Post subject: Reply with quote
Thanks deMort! There is a bit of smoke on start up same as always, but nothing too excessive that has me worried.
And I've noticed the spashback on the drivers side outer rear wheel so figure the oil leak is that side.
Spoon is a great idea👍
1968 911T
2002 996 4s
1988 944 (Sold)
PostPosted: Sat Feb 16, 2019 7:50 pm    Post subject: Reply with quote
Small amount of smoke on start up with ANY flat engine is normal .. you only start to worry when its prolonged or doesnt stop .. and even then its normally an AOS .
When we start talking engine damage we have other symptoms none of which you have mentioned .
An oil leak can indeed cover a rear bumper / pu .. again rare and it has to be a pretty bad leak to do this .. atm from your picture im leaning towards water from the exhaust and you only see it this time of year due to the shear amount of road salt and crap on the roads atm .
Im a biker . i hate this time of year .. half way to work and my helemt visor is covered in it to the point i struggle to see !
toddy2
PostPosted: Sat Feb 16, 2019 8:21 pm    Post subject: Reply with quote
Thanks again, fair amount of oil lost overnight yesterday.
Ahh my days of riding all year round are over, I couldn't hack the cold getting in every nook and cranny, and remember spraying fog on the inside of the visor - you're a braver man than me Thumb
1968 911T
2002 996 4s
1988 944 (Sold)
 Filesize:  713.99 KB
 Viewed:  1227 Time(s)
PostPosted: Sat Feb 16, 2019 8:29 pm    Post subject: Reply with quote
Aghh ok .. an oil leak if its on the ground .. just need to find what part is leaking ...
Do me a favour though .. try and stick your head underneath .. 997 that side and there is the tandem pump .. if thats leaking it can start to leak .. rather a lot more shall we say and is worth investigateing .
Or strick your phone there and take several pictures .. we may get lucky .
I know the bike feeling well .. times when i dont like it .. but very few .. also im 54 Very Happy but heated grips .. fingers warm and that will do me lol .
toddy2
PostPosted: Sat Feb 16, 2019 8:43 pm    Post subject: Reply with quote
Nothing obvious, it's been parked up for a couple of hours and I placed a timber board under so to try and measure whereabouts the leak might be.
Just spotted my under tray is missing too!
1968 911T
2002 996 4s
1988 944 (Sold)
 Filesize:  463.34 KB
 Viewed:  1190 Time(s)
 Filesize:  478.43 KB
 Filesize:  413.27 KB
 Filesize:  352.39 KB
 Filesize:  393.85 KB
 Filesize:  418.39 KB
 Filesize:  315.35 KB
 Filesize:  669.72 KB
 Filesize:  564.83 KB
 Filesize:  454.19 KB
PostPosted: Sat Feb 16, 2019 8:46 pm    Post subject: Reply with quote
There is nothing there that i would consider an oil leak .. a few sweat marks but nothing blowing back ..
Im afraid im back to montior it as i think the marks on the PU may just be water out of the exhaust and this time of year with grime buildup .
may be possibly at the gearbox end .. but no oil is showing towards the rear .
toddy2
PostPosted: Sat Feb 16, 2019 8:54 pm    Post subject: Reply with quote
Thanks again deMort, alway appreciate your dedicated responses.
I'll take another look in the morning, see if there is anything from the gearbox. I wanted to take it in for a service in any event, I'll get this booked in next week. So will ask them to explore.
1968 911T
2002 996 4s
1988 944 (Sold)
Hans Gruber
2002 Porsche 996 Carrera 4S
PostPosted: Sat Feb 16, 2019 9:08 pm    Post subject: Reply with quote
I wouldn’t worry too much about the mayo, particularly in light of the recent short journeys.
As for the oil on the rear PU and the drops of oil under the car, I had exactly the same thing not too long ago...more noticeable after a somewhat spirited run on the M62.
My local Indy identified it quickly, and fixed it for not too much cash. I have to admit, without sounding too Rowley Birkin QC, I have had a couple of glasses of vino and can’t remember what the issue was exactly. I know it was something that required a seal replacing and that something or other needing locking so I didn’t fancy it myself.
I’m sure deMort will be along shortly to identify the issue based on my flimsy description.
I would go and dig out the invoice and tell you what it was but ‘Shaun of the Dead’ has just started. And I’m very, very drunk....
2002 Porsche Carrera 4s
2008 Saab 9-3 Aero ttid - Sold, not arsed
2013 Kawasaki ZX6R - Sold not sorry
2019 Skoda Superb Estate - Bored
toddy2
PostPosted: Sat Feb 16, 2019 9:12 pm    Post subject: Reply with quote
Thanks for the reassurance Hans Grubber.
I'll book it and get it checked out Thumb
1968 911T
2002 996 4s
1988 944 (Sold)
Hans Gruber
PostPosted: Sat Feb 16, 2019 9:33 pm    Post subject: Reply with quote
Had a look through the file during the ad break and it was the timing chain tensioner seal. Worth a look. I must admit when I saw oil on the back PU my back side literally fell out but it turned out to be a storm in a tea cup.
Good luck
toddy2
PostPosted: Sun Feb 17, 2019 5:32 am    Post subject: Reply with quote
Good luck
Thanks good to know Thumb
1968 911T
2002 996 4s
1988 944 (Sold)
toddy2
PostPosted: Sun Feb 17, 2019 8:33 am    Post subject: Reply with quote
UPDATE - Jacked the car up this morning and found the leak is coming from the gearbox. It had been notchy and feared '2nd gear pop out' was coming. I'll book it in and see what's up.
1968 911T
2002 996 4s
1988 944 (Sold)
alex yates
PostPosted: Sun Feb 17, 2019 8:41 am    Post subject: Reply with quote
The actual gearbox or where it bolts to the back of the engine? Could be rms or ims seal.
toddy2
PostPosted: Sun Feb 17, 2019 2:04 pm    Post subject: Reply with quote
Thanks Alex,
I'll need to get it on a lift and shine a torch to be sure. But I reckon it's from the front end of the gearbox, the under tray is quite wet from oil. As far as I can see there is no place in the front end of the gearbox oil could leak from, no loose bolts or anything.
1968 911T
2002 996 4s
1988 944 (Sold)
