991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
ukrr
PostPosted: Sat Feb 16, 2019 4:20 pm    Post subject: Pvts sim warning light Reply with quote
Hi - I’m after a bit of help. I have a preowned 981 which I got from
an Opc without the tracker fobs. Now am getting a SIM card warning light. How can I get rid of the warning or failing that any clues where the previous owner might have ‘hidden’ the fobs in a 991. I’ll call the Opc next week but just wondered if anyone had any insights ?
mark pearce
Approved Trader
PostPosted: Sat Feb 16, 2019 4:30 pm    Post subject: Reply with quote
I think its because the subscription is still active
Give Vodafone telematics a ring, they might if they're in good mood confirm , deny and delete the subscription,
The problem is when you cancel the subscription, Vodafone send a text message to the care, if the ignition is on the text gets rejected and they don't bother to resend it
Stirlings The Low Mileage Porsche Specialists
mark@stirlings.co.uk
Tel 01736 757755
www.stirlings.co.uk
Passion for Perfection
Why risk the alternative?
ukrr
PostPosted: Sat Feb 16, 2019 4:50 pm    Post subject: Reply with quote
Many thanks Mark
PostPosted: Sat Feb 16, 2019 4:54 pm    Post subject: Reply with quote
From memory i think that Normally you will get this warning message anytime the car cant see a fob .. as you have had the car a while ? and it hasnt done this then im inclined to think there is a fob in the car but the battery has now died in it .
Glove box , center cubby and door pockets are the usual but i think you would have found it by now ..
Check the book pack , its not tucked away in there is it ?
To deactivate the system you will need either an OPC or an Indy with the right tester .
Phone Vodaphone first though .. i may be totally wrong but the above is what i seem to remember .
ukrr
PostPosted: Sat Feb 16, 2019 5:01 pm    Post subject: Reply with quote
Many thanks
