car has been off road for a few months over winter so I took car out for a steady drive until warmed up, approx 10 mile. put foot down to blow the cobwebs out and car lurched and I heard a loud pop and check engine light came on. I stopped the car and found right and turbo hose had blown off at the upper connection behind wheel arch liner!trouble is it blew the connection with the wire clip not the jubilee lower down. what could be possible cause of it blowing off like that guys...apart from obviously not being fitted right previously ( I know that's not the case though, so that is ruled out)!
this happened several days ago. since then iv disconnected battery to rid the check engine light but it comes back on after a short while 5 to 10 mins. also the oil check light on dash kenos saying engine not up to temperature. takes a bout 15 to 20 mins then it reads and says engine oil level correct.
on start up oil pressure in middle and when accelerator is applied goes up to 4 0r 5
