997 : 2004- 77
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 12
mikeluke
PostPosted: Mon Feb 11, 2019 10:34 pm    Post subject: Anyone Trying Wrapping a Desk/Table? Reply with quote
Just redecorated the home office and my very practical and spacious desk looks out of place. It has a wood finish (laminate) and the room is grey/white. I was thinking about wrapping it in vinyl to help it blend in. Anyone got any experience/tips out there? I am thinking that if car vinyl can take weather and washing it should be tough enough to cover my desk in....
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
VW Polo Match 1.2 (the lad's)
Former:
996 Turbo S Cabrio Manual
996 Turbo Coupe Tip
968 Cabrio Manual
kurlykris
PostPosted: Mon Feb 11, 2019 10:42 pm    Post subject: Reply with quote
Never tried it myself, but the only problem I can see is if the desk has sharp 90 degree corners which would be pretty difficult to get just right and might be easily damaged.
Bring back "Blue Peter" I say, sticky back plastic all the way thumbsup
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Thefinn
PostPosted: Tue Feb 12, 2019 3:32 pm    Post subject: Reply with quote
Through work i have had people in the past wrap flat sheets of melamine or overlay the flat part of check out desks etc. which does work and stick, but as said the corners will be difficult as you will probably have to cut the vinyl. Also if you do the top of the desk it will probably tear when you drop things on it or catch it so if you want to go down this route you might want to think about a perspex / glass sheet on top or alternatively you can buy coloured laminate sheet but this is incredibly difficult to cut with a clean edge and has a tendency to snap when you are working with it, plus it will cost a few quid. On the corners if you do cut the wrap you might want to look at installing a protective metal corner on top of the cuts so that you don't snag and lift the vinyl with your arm or as you walk past.
You could paint it but you will need to prime it first with a product such a zinzer but this will also scratch over time, so you will be doing it again soon.
unless the desk is is an expensive one that you can't get rid of i would just stick that on gumtree and get a new one that suits as the cost of the wrap / paint / glass and time spent might not be worth the hassle.
just my 10 pence
997.1 C4S CAB
mikeluke
PostPosted: Tue Feb 12, 2019 4:06 pm    Post subject: Reply with quote
Thanks!
Decided to give it a go and I have bought some corners to provide protection - and cover the joins!
Smile
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
Former:
996 Turbo Coupe Tip
968 Cabrio Manual
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Tue Feb 12, 2019 11:19 pm    Post subject: Reply with quote
Have you gone for carbon fibre wrap?
or
Are you going to add decals?
and
Have you thought about Martini livery?
chicb
PostPosted: Tue Feb 12, 2019 11:28 pm    Post subject: Reply with quote
Spotless Detailling in Perth have recently done this. Think its on their Facebook page
mikeluke
PostPosted: Wed Feb 13, 2019 9:22 am    Post subject: Reply with quote
Ah.... Don't use Facebook. (Or Instagram, Snapchat, Twitter etc either)
This forum is the closest that I get to social media!
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
Former:
996 Turbo Coupe Tip
968 Cabrio Manual
mikeluke
PostPosted: Wed Feb 13, 2019 9:24 am    Post subject: Reply with quote
or
and
I'm afraid it is boring, dull matt grey - to sort of match the office furniture! Getting the spray bottle and squeegie ready
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
Former:
996 Turbo Coupe Tip
968 Cabrio Manual
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Feb 13, 2019 10:38 am    Post subject: Reply with quote
Good simple object to start with.
Next week you'll be doing your car like Infrasilver did!
mikeluke
PostPosted: Wed Feb 13, 2019 10:40 am    Post subject: Reply with quote
mmmm. I could wrap the lad's Polo whilst he is away at uni.....
Do you think that he'd appreciate the change from white to Barbie Pink?
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
Former:
996 Turbo Coupe Tip
968 Cabrio Manual
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Wed Feb 13, 2019 11:30 am    Post subject: Reply with quote
Not nearly as tricky as a table might be but I wrapped my B&W stereo speakers in white. Previously they were a dark woodgrain type finish. not tricky at all, just take your time and if you could ever make an Airfix model it's a doddle !Thumb
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
 Filesize:  242.5 KB
 Viewed:  685 Time(s)
 Filesize:  295.2 KB
 Viewed:  685 Time(s)
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Feb 15, 2019 2:04 pm    Post subject: Reply with quote
Yes maybe. Grin
The desk top corners of the wrap material will stretch with heat and won't be seen, there is a technique to it but a little practice on the corners alone before the final covering will help.
You basically overheat the material and stretch the area around the corner out first before laying down, then use the heat gun to shrink the material back towards the corner, pull down over the corner and trim the lower edges, there will be no join to see.
mikeluke
PostPosted: Fri Feb 15, 2019 3:19 pm    Post subject: Reply with quote
Vinyl has arrived but no sign of my applicator thingy...
Will have to see what I have in the cupboard, as I was planning on doing this tomorrow
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
Former:
996 Turbo Coupe Tip
968 Cabrio Manual
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Fri Feb 15, 2019 3:23 pm    Post subject: Reply with quote
And make sure the surface is spotlessly clean and grease free or it won't stick.
mikeluke
PostPosted: Sun Feb 17, 2019 5:52 pm    Post subject: Reply with quote
So, I did it today - 95% OK - learnings...
Handling a large sheet of wrap on your own is tough
You need to be very careful not to crease the wrap before you apply it - getting them out is a bar steward
Hair dryer and streeettch works well on the corners
Current:
981 Boxster S PDK
BMW X5 4.0d M Sport
BMW M140i (Mrs L's)
Former:
996 Turbo Coupe Tip
968 Cabrio Manual
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Feb 17, 2019 10:32 pm    Post subject: Reply with quote
Blowing hot air on the creases get them out easily.
Now, pictures required...
