997 : 2004- 74
996 : 1997-2005 29
Boxster : 1997- 14
Jam911
PostPosted: Mon Feb 11, 2019 10:00 pm    Post subject: Brake Caliper Bleed Screws - Recommendations Please Reply with quote
I am going to replace my brake caliper bleed screws and am looking for recommendations please.
Stainless / titanium ?
Where to buy?
Also sizes and tips on doing the job.
Current '07 997 C4S
Ex '99 2.5 Boxster
maldren
PostPosted: Tue Feb 12, 2019 8:58 am    Post subject: Reply with quote
Stainless are fine, you don't really need the weight saving!?!?
I bought mine from Hel, a reputable make and only £15.94 for 8. I also bought rubber covers separately from China, not a good move, they haven't lasted well.
Take care when removing the old nipples, some of mine were almost seized. The outer ones were fine, the inner ones weren't. I soaked them for a day with Plus Gas and then used a T bar (not a spanner) to make sure that I didn't accidentally put a bending load on them.
Mike
Mike
hedgehogsdad
PostPosted: Tue Feb 12, 2019 9:14 am    Post subject: Reply with quote
Mike
My local OPC wouldn't do a fluid change on my car at the last service because the nipples wouldn't budge, and they told me that if they stripped a thread then the only option was a new caliper. Surprised
Realistically, how much pressure can you put on a tight bleed nipple without causing damage?
Any other tips as I could do with getting mine sorted?
2006 997 Turbo
2003 996 Turbo
2006 Cayenne
1999 996 C2
1990 964 C2 Targa
1980 SC
Jam911
PostPosted: Tue Feb 12, 2019 12:52 pm    Post subject: Reply with quote
Hi Mike
Can you tell me which ones you got from Hel as there are a few types on the web site.
James
Current '07 997 C4S
Ex '99 2.5 Boxster
MarkC4S
PostPosted: Wed Feb 13, 2019 9:16 am    Post subject: Reply with quote
Early into ownership I had this worry when two OPCs failed to get a nipple off, warning that if they tried harder it could snap off and cost me a caliper (£800).
Thanks to this forum I found a supplier (friendly and helpful) who could not only supply the correct stainless nipples (warning - found incorrect ones offered on eBay for my car), but if the nipple did snap, I could take it off and run it up to him and he would remove it and send me on my way to re-fit.
In the end my local trusted garage got the nipple out without a real struggle and I fitted stainless all round - result!
https://pro-calipers.co.uk/price-list/
Good luck
maldren
PostPosted: Wed Feb 13, 2019 9:18 am    Post subject: Reply with quote
Jam911 wrote:
Hi Mike
James
The receipt says:
BNM10X100 HEL Stainless Steel Bleed nipple M10*1.00
Hope this helps. I wish I'd changed the hoses at the same time, their parts look good.
Mike
Mike
Jam911
PostPosted: Wed Feb 13, 2019 7:39 pm    Post subject: Reply with quote
Thank you very much
Current '07 997 C4S
Ex '99 2.5 Boxster
