991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
996lee
PostPosted: Mon Feb 11, 2019 11:48 am    Post subject: 3.4 engine seized a few questions / put me out my misery :-( Reply with quote
Hi all
had a nightmare of a weekend nooo
my car was booked in for a full service and to have a coolant leak sorted and once again having another split on a dansk flexi joint sorted last friday
i was already expecting it to be an expensive weekend however....
the day prior i did about 400 miles in it but as i went to start it that morning there was a screeching sort of sound after it fired up!
which in my mind was possibly the starter motor giving up the ghost (has had a few slow cranks when hot over the last couple of weeks)
anyway on the return leg of my jouney after fueling up i went to start it and it went to turn over but felt like the whole engine was going to turn over with it
second attempt it fired but same again it felt a really heavy turn over which worried me
i got out listened to it and it was ticking over just fine and got me home with no fault at all
the following morning i go to start it and all i got was a single click
quickly got my jump leads out and still just a single click
not wanting to miss my slot at the garage i then tried to bump start it
on attempting this on letting out the clutch it locked its wheels
so thinking it was just me not building up enough speed i got my dad round and we used his car to tow it
and the same happend
i tried rocking it backwards and forwards in gear and the engine is seized solid
i did try hitting the starter motor a few times
and after that the click did sound more convincing that it was going to turn
i then got it towed to Zentrum in Nottingham obviously expected the diagnosis to be the worst
i was late for my slot so they are stripping bits off it today/tuesday to see what is wrong
but they have already told me they they removed the sump and thats clean with no trace of metal but they can see the flywheel is trashed (this is only a couple of years old lightweight flywheel)
so my question is could a stuck starter motor do that damage?
i'm aware i've not helped matters trying to bump start it if so
and secondly if this is likely what has seized the engine
what are the chances that 2 attempts to bump start it and it locking the wheels has trashed the crankshaft/ anything else whilst doing so?
sorry for the long post i'm obviously pretty gutted that a rebuild may be needed Sad
2001 Carrera 4 aero all the way!!
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Feb 11, 2019 11:54 am    Post subject: Reply with quote
I'm sure that Mike will be able to tell you pretty quickly. Best hope is that something on the flywheel failed which has locked it up from there, no engine damage. Could be snapped crankshaft which might 'just' mean a new crankshaft and no other engine damage.
Fingers crossed for you, somewhere between a new crank and a new engine is my guess. Good used 3.4l cranks are unfortunately like rocking horse sh!t.
PostPosted: Mon Feb 11, 2019 12:26 pm    Post subject: Reply with quote
My guess is this is all flywheel related and your engine is fine.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Feb 11, 2019 12:43 pm    Post subject: Reply with quote
Yeah as MC and Alex says sounds to me like the flywheel teeth are maybe damaged and holding onto the starter cog. Maybe the starter got lazy at retracting (that would be the screeching sound you heard).
Was it an alloy flywheel?
If thats the case just chuck an OE dual mass on. Hopefully no damage to the crank or main bearing from the bump start attempt.
PostPosted: Mon Feb 11, 2019 12:55 pm    Post subject: Reply with quote
Can't see any damage occuring bumping it as the only thing in motion is the gearbox and the locked flywheel has taken the brunt of that. No load would've been put on the engine. If amything, the gearbox/diff/driveshafts may be damaged but I doubt it.
Marky911
PostPosted: Mon Feb 11, 2019 1:25 pm    Post subject: Reply with quote
Nightmare Lee.
Hopefully it’s whats mentioned above and the engine has in fact survived.
Fingers crossed for you.
996lee
PostPosted: Mon Feb 11, 2019 1:35 pm    Post subject: Reply with quote
I'm keeping my fingers crossed and waiting for the phone call
@wasz It is a alloy flywheel I believe (from rpm technic that they use on their csr's)
wasz
PostPosted: Mon Feb 11, 2019 1:53 pm    Post subject: Reply with quote
So alloy being softer than steel the teeth on the flywheel could have been damaged by the teeth of the starter which failed to retract properly, and then the next time you start the damaged teeth hold onto the starter even more and then the starter gets bent / stuck / whatever seizing the transmission.
Thats my internet diagnosis Very Happy
Either that or its the other internet diagnosis of AARAGH IMS BEARING FAILURE and OMG BORE SCORE but I doubt it.
PostPosted: Mon Feb 11, 2019 1:59 pm    Post subject: Reply with quote
I second my learned friend with that diagnosis.
996lee
PostPosted: Mon Feb 11, 2019 2:20 pm    Post subject: Reply with quote
right had a call off mike at zentrum
it was indeed the started motor seized solid that had mangled the teeth of the flywheel
and there is no damage to the crank or anything else
and also good news was my coolant leak just needed a new jubilee clip to sort Thumb
now i have absolutely loved my lightweight flywheel and the prices are around the the same as a dual mass so do i go for another Question
PostPosted: Mon Feb 11, 2019 2:28 pm    Post subject: Reply with quote
Only if you sort your sticky starter motor out 1st.
996lee
PostPosted: Mon Feb 11, 2019 2:33 pm    Post subject: Reply with quote
yep they are fitting me a new one Thumb
maldren
PostPosted: Mon Feb 11, 2019 2:36 pm    Post subject: Reply with quote
Not sure I fully agree with Wasz, I would expect that the ring gear on the flywheel is steel and shrunk onto the alloy flywheel, cast iron flywheels are usually like this.
If the flywheel is undamaged, it may be possible to just have a new ring gear fitted and saving quite a lot - try asking the manufacturer.
Mike
996lee
PostPosted: Mon Feb 11, 2019 2:50 pm    Post subject: Reply with quote
i'll dig out the pic i took of it when it arrived (if photobucket still exists now)but if i remember correctly it was a one piece flywheel
i may be mistaken though
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Mon Feb 11, 2019 4:43 pm    Post subject: Reply with quote
It definitely will be a steel gear ring around the flywheel, it wouldnt last more than 3 or 4 goes if the teeth were alloy. New starter ring onto the flywheel, new starter and off you go Smile
996lee
PostPosted: Mon Feb 11, 2019 7:13 pm    Post subject: Reply with quote
Here's the pic i took when it arrived
PostPosted: Mon Feb 11, 2019 8:08 pm    Post subject: Reply with quote
When i first started reading this i was thinking coolant in a cylinder .. hydraulic lock .. to be a siezed starter motor .. i can honestly say in 37 years of fixing cars i have never seen nor herd of this .. and thats every make of car as ive only been on Porsche for 15 years .
Pretty good news compaired to what it might have been .
Now then lightweight flywheel ..
Ill just say that i think Porsche did an awfull lot of R&D on these cars in the design phase .. they decided on a duel mass flywheel ..
Other companys decided they new better and did this light weight flywheel .. im not convinvced these companys new more than Porsche or tested it as much ..
But as always i leave that sort of descion up to the customer .. i fit the parts Porsche have specified and leave it at that .
End of the day though .. phew !!!
kas750
Reims
2006 Porsche 911
PostPosted: Mon Feb 11, 2019 8:36 pm    Post subject: Reply with quote
Indeed! Thumb
jond58
PostPosted: Mon Feb 11, 2019 9:17 pm    Post subject: Reply with quote
The dual mass is designed to deal with vibration, flexing and the torque delivered to the gearbox. How did it drive with a solid flywheel? Every car Ive driven with one that should have been on dual mass was noisy and vibey and generally a pain in the arse!!
996lee
PostPosted: Mon Feb 11, 2019 9:25 pm    Post subject: Reply with quote
I'll admit it's probably an acquired taste and did chatter a little and if you let the revs drop too low in gear then yes you got some vibration
But I think it was worth it for how much quicker it revs
