997 : 2004- 70
Boxster : 1997- 20
Cayman : 2005- 14
cyanescent
PostPosted: Sun Feb 10, 2019 4:46 pm    Post subject: strange pumping noise coming from front Reply with quote
New owner here - so I bought my 997 C4S (2007) a couple of months ago. Yesterday when driving through town, noticed a strange pumping noise coming from the front - a bit like a pump with liquid swooshing and a regular clicking noise. It only occurred when moving - when stopped, it went away. after I pulled over and looked in the frunk and the various compartments, couldn't see anything obvious, so I continued driving. It then stopped making the noise.
Just wondering if this is a normal thing? it was the first time I'd really noticed it, probably because driving slowly through town, so the engine didn't drown everything out... just nervous about strange noises! I did wonder if perhaps it was fluid being pumped through the radiators or something?
Thanks for any advice Smile
PostPosted: Sun Feb 10, 2019 4:57 pm    Post subject: Reply with quote
When it does it does depressing your clutch make any difference?
cyanescent
PostPosted: Sun Feb 10, 2019 5:07 pm    Post subject: Reply with quote
Can't remember - I will keep an ear out and see if that changes anything if it happens again. What would that imply?
thanks.
vlad
PostPosted: Sun Feb 10, 2019 5:12 pm    Post subject: Reply with quote
Headlight washer jets Dont know
Every so many squirts on the washer on the windscreen these pop-up, you weren't cleaning your windscreen at the time ?
Gazc2
PostPosted: Sun Feb 10, 2019 5:29 pm    Post subject: Reply with quote
Is it a gurgling noise ? if it is your A/C needs topped up
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
PostPosted: Sun Feb 10, 2019 5:35 pm    Post subject: Reply with quote
Yeah
cyanescent
PostPosted: Sun Feb 10, 2019 5:37 pm    Post subject: Reply with quote
nope - wasn't cleaning windscreen or headlight washers. I regularly blip the headlight washers to stop them gunking up too.
Iwantone
^This if it is gurgling and sounds like it is coming from the back of the centre console
Current:
2010 C2S Cabriolet, in speed YELLOW
Previous:
2009 Gen II C4S
1988 Carrera 3.2
and various non-Porsche in between
cyanescent
PostPosted: Sun Feb 10, 2019 5:39 pm    Post subject: Reply with quote
bit of a gurgling/swooshing noise, like something pumping liquid/air... heater temp is set to around 25C at the moment... but it stopped making the noise after a bit...
cyanescent
PostPosted: Sun Feb 10, 2019 5:40 pm    Post subject: Reply with quote
yeah, from the back of the centre console....
so if it is that, how urgent is it? :<
PostPosted: Sun Feb 10, 2019 6:12 pm    Post subject: Reply with quote
Sit in the car stationary with the engine running , a/c on temp at 19.5 and a fan speed of 3 bars ..
Give it a few mins and see if the noise starts .. if it doesnt then probably not a/c but if the noise starts then turn off the a/c .. if it stops then you have just proved its low a/c gass .
cyanescent
PostPosted: Sun Feb 10, 2019 6:38 pm    Post subject: Reply with quote
Thanks - will try that this week!
cyanescent
PostPosted: Wed May 22, 2019 12:14 pm    Post subject: Reply with quote
it's been quite a while without an update - sorry - a lot of travel and the noise vanished and didn't reoccur...
However, I just had it serviced, and it turns out that it very likely was the air-con - they found that the radiator for the aircon was cracked, so required replacing, new condenser, and regassing. I just wouldn't have noticed the air con not really running because it's been so cold in the UK until now!
Anyway, it's all replaced (warranty, thankfully!) so it's all good now. Thanks for the responses - it was very helpful and nice to get the support Smile
