997 : 2004- 73
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
rich07
PostPosted: Sun Feb 10, 2019 11:23 am    Post subject: ordering replacement fan bearing, size? Reply with quote
Hi guys, just in the middle of alternator fan and shroud refurbishment, rather than pay a rediculous amount of money for the bearing and hub from porsche or aftermarket suppliers has anyone measured and ordered the bearing from a supplier? I don't trust my measuring skills.
Thanks rich
PostPosted: Sun Feb 10, 2019 11:54 am    Post subject: Reply with quote
I think Ninemeister carry them in stock. I found that out after mine was ordered from OPC and had to be couriered from Germany Rolling Eyes
Here is the one you want:
http://wmtbearings.co.uk/porsche-pulley-bearing-ld17-32-2rsr-an04/
Or £15 off eBay I think? That said they should be under £20
decgraham
PostPosted: Sun Feb 10, 2019 2:40 pm    Post subject: Reply with quote
Hi rich07,
We did a group buy back in June last year and as Zingari says WMTBearings is the company to go to.
Here's the link for your info.
http://911uk.com/viewtopic.php?t=128412&highlight=bearing
ATB Smile
rich07
PostPosted: Sun Feb 10, 2019 5:18 pm    Post subject: Reply with quote
Thanks guys, great info, will get that ordered asap, especially as the start of warmer weather is on its way, brighter evenings etc.
rich07
PostPosted: Mon Feb 18, 2019 10:40 pm    Post subject: v belts Reply with quote
Hi guys, alternator all back together, new voltage regulator and fan bearing installed. I am having trouble with the belts, porsche have supplied two both the same, alternator and fan, the alternator belt is to slack even with all the shims removed?
 Filesize:  1.95 MB
 Viewed:  1049 Time(s)
Diddi
PostPosted: Mon Feb 18, 2019 11:50 pm    Post subject: Reply with quote
Hi, which engine number is installed M64.?? there are different "Schmalkeilriemen" of the length for that.
Grüsse, Diddi
Diddi
Grüsse, Diddi
rich07
PostPosted: Tue Feb 19, 2019 12:08 am    Post subject: Reply with quote
Yes I think so, service book it says
M6405-63R G5021-10
Diddi
PostPosted: Tue Feb 19, 2019 12:39 am    Post subject: Reply with quote
.......for M64.05 is 9.5 x 776 (999 192 338 50)
the next is 9.5 x 760 (999 192 343 50) and then 9.5 x 753 (999 192 373 50)
the order numbers for the belts in brackets
Grüsse, Diddi
decgraham
PostPosted: Tue Feb 19, 2019 7:45 am    Post subject: Reply with quote
Rich, is your car a Tip? mine is and the 2 belts are a different size. See link:
https://type911shop.co.uk/epages/de867ca1-377e-432e-84fd-bdccf2206766.sf/en_GB/?ObjectPath=/Shops/de867ca1-377e-432e-84fd-bdccf2206766/Products/3046
Whereas for a Coupe they are both the same on the Type 911 site.
I bought the above and they fitted just fine.
ATB Smile
rich07
PostPosted: Tue Feb 19, 2019 8:38 am    Post subject: Reply with quote
Hi, it's a manual.....
so it looks like I have the right belt?
I emailed the parts guy at porsche, he says it may be to do with a tech update that mean the pully halves also need to be replaced. He's going look into it and let me know.
decgraham
PostPosted: Tue Feb 19, 2019 8:46 am    Post subject: Reply with quote
Hi Rich,
OK that sounds right to me. I'm attaching the "Pulley Update" from Porsche for your info.
ATB Smile
Pulley_update.pdf
Download
 Filename:  Pulley_update.pdf
 Filesize:  32.35 KB
 Downloaded:  18 Time(s)
rich07
PostPosted: Tue Feb 19, 2019 4:06 pm    Post subject: Reply with quote
Hi thanks for that, it's a shame porsche didn't realise that the pully needed to be changed when they gave me the new belt, pulley arrives on Thursday, so fingers crossed for a drive at the weekend.
decgraham
PostPosted: Tue Feb 19, 2019 4:08 pm    Post subject: Reply with quote
ATB Smile
