997 : 2004- 76
964 : 1989-1993 4
Boxster : 1997- 16
Cayman : 2005- 18
MNC911
PostPosted: Sat Feb 09, 2019 2:06 pm    Post subject: 997.2 brake discs & pads wanted - best place to buy? Reply with quote
Hi guys
M-O-T this morning, only an advisory - inner front disks faces slightly corroded (common as we all know)
Where's the best place to get a new Original Equipment set & pads apart from OPC.
Car is coming to end of warranty so I can either go down the O.E.M route and takes my chances on repairs or buy O.E. and renew the Porsche Warranty. To be fair that warranty has been a god send.
Matt
History:
'10 911 Cab
'13 Cayman
'02 Boxster
MJA911
2012 Porsche 991 Carrera
PostPosted: Sat Feb 09, 2019 4:49 pm    Post subject: Reply with quote
On the 997.2 I believe Sebro discs are indistinguishable from Porsche OE discs, in that they’re made by Sebro. You should be able to source them for around £100 per disc, usual suspects all worth a look, Eurocarparts usually competitive.
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
MNC911
PostPosted: Sat Feb 09, 2019 6:40 pm    Post subject: Reply with quote
I sent eurocarparts a message and they don't supply original parts, only aftermarket items to the same size etc. However in the same response they did say if I supply part numbers they can see if it is a possibility to buy in and resale
I think these are the disk part numbers L/R hands 99735140101 & 201
History:
'10 911 Cab
'13 Cayman
'02 Boxster
