997 : 2004- 74
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
peter y.s pang
PostPosted: Fri Feb 08, 2019 2:39 am    Post subject: Re: Knocking sound on uneven road Reply with quote
Hi, My 993 rear end with knocking sound when running on uneven road. But it don't have any sound when running smooth road and on highway. Checked all heat protection plate all in good condition and fitting tight. The exhaust system all fitting tight. I did renew all control arm 1 year ago.
My question is, Will the knocking sound from the CV axel ? It already over 20 years. Even the rubber dust bellow look ok, Will inside the grease dry up ? Any method to check the CV axel.
Thanks for any input for me to trace such knocking sound.
Peter
1996 993 C2 Tip /speedyellow 17" Fuchs wheel. Bilstern B6 shock .
Endoman
PostPosted: Fri Feb 08, 2019 6:31 pm    Post subject: Reply with quote
Could be from any suspension component. Commonest is the arb drop link, followed by the lower wishbone monoball.
I had a knock from a loose adjuster bolt on one of the control arms which had not been torqued up. Wheels off and go round with a pry bar, check for split bushes and tightness of mounting bolts.
hopeydaze
PostPosted: Fri Feb 08, 2019 8:48 pm    Post subject: Reply with quote
Depending on where you live, this is a good reason to pay a visit to Center Gravity. They found a few issues on my 993
