Posted: Thu Feb 07, 2019 2:00 pm Post subject: Eccentric rear toe arm bolts - cheaper option
I've just got some new bolts for doing my rear toe arms. After measuring up it looks like they're the same or similar to the VAG ones. Only difference I can see are the VAG state 35mm diameter washer and the Porsche are 37mm on the bolt head washer.
Length are 82.5mm and thread M12 x 1.5mm pitch.
Set for £24 here and plenty of places selling them so easier to acquire:
I was gonna do that but too much faff if you're nowhere near an OPC and too busy at work. _________________ 2000 Manual 996 C4 Arctic Silver Convertible
infrasilver Fast & Furious
Joined: 04 Oct 2010 Posts: 8507 Location: East Midlands
The extra 1mm will make a difference to the amount of adjustment you can make, if your settings are not anywhere near the end adjustment you may be fine? _________________ http://euroroadtripper.blogspot.co.uk/
Alex Le Mans
Joined: 06 Mar 2014 Posts: 17144 Location: The Ribble Valley, Lancashire
I'm not convinced the Audis are 35mm or the Porsche 37mm as the OD is that crude on them. _________________ 2000 Manual 996 C4 Arctic Silver Convertible
