996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
MattyR
PostPosted: Wed Feb 06, 2019 10:25 am    Post subject: 997.2 Resonator block-off Reply with quote
Is there anyway to block off the resonator connected to the main air intake hose; thus producing a fruitier note to an otherwise standard 997.2 Carrera?
Is there a silicone cap one can obtain which allows the original hose to be re-attached so all appears standard?
Cheers!
Atlas Grau on Ocean Blue Gen 2 997 C2 Carrera
Sold: Aventura Grün 993 C2 Carrera
ninenineseven
PostPosted: Wed Feb 06, 2019 10:44 am    Post subject: Re: 997.2 Resonator block-off Reply with quote
Cheers!
Does yours definitely have a resonator? My 2010 C2 air box doesn't have one at all as I was hoping to take a vacuum feed from it but the design of my air box is different to a C2S it seems.
DucatiRob
PostPosted: Wed Feb 06, 2019 11:51 am    Post subject: Reply with quote
Cut the top off shampoo bottle, fitted under the connector, works a treat! £0 Very Happy ... on a Gen1
Mercedes CLK DD
Ducati 996
alex yates
PostPosted: Wed Feb 06, 2019 12:27 pm    Post subject: Reply with quote
You need to make a sketch of what you want then get someone like me to turn you one up out of aluminium.
FZP
PostPosted: Wed Feb 06, 2019 12:32 pm    Post subject: Reply with quote
Pop Corn
PostPosted: Wed Feb 06, 2019 12:43 pm    Post subject: Reply with quote
Matty, the gen2 does have a resonator and unlike the GTS that has 6 modes in the resonator the S only has 1 mode , it is integrated unlike the gen1 resonator . this I think is the reason there is no mod fix for it.
I have read numerous reports of guys changing the openings on the bottom of the gen2 airbox and adding white mesh , has yours got no mesh or black mesh if so it seems changing it to the white mesh type will give a sound upgrade. I haven't done this mod so can only say what I have read. Personally I started with BMC sports filters which gave a small sound gain then fitted a fabspeed carbon twin code performance induction , this made a considerable induction note gain.
Personally and not knowing what you have or haven't done to get a better noice from the car , but start with BMC sports filters circa £150 then fit a rear muffler bypass circa £300 then if you still not exited by the sound of your gen2 then options are gundo hack the rear boxes circa £300 or fit an aftermarket sports exhaust anything from £800 to £5k .
If you decide to do the same as me and go for the fabspeed twin cone you will need a remap as the parameters are to big for the car to relearn the values. Thumb Thumb
 Filesize:  117.11 KB
 Viewed:  238 Time(s)
MattyR
PostPosted: Wed Feb 06, 2019 1:40 pm    Post subject: Reply with quote
Thanks gentlemen, outstanding as always. Phil, nice response, thank you.
It would seem that the gen 2 is an integrated resonator (more Googling!). Alas, I was hoping for a quick fix like the gen 1 and my old 993.
My car is totally standard, which seems daft. It’s my daily right now and I’ve done about 5k miles so just working out what direction I want to take things. There’s some truly inspiring threads on this forum.
baldguy
PostPosted: Wed Feb 06, 2019 1:41 pm    Post subject: Reply with quote
I'll gladly pay for one made from you Alex - 996 C4 2001
Let me know fella...
ninenineseven
PostPosted: Wed Feb 06, 2019 1:42 pm    Post subject: Reply with quote
Mine doesn't (3.6). Dont know
