991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
t1x
PostPosted: Tue Feb 05, 2019 11:37 pm    Post subject: Help - PCM problems 2.1 Reply with quote
Hi all,
Its been a while. Time for your advice if possible.
I have a problem with my PCM 2.1. Before you all say replace it with an after market unit, I want to keep it original if possible.
The problem:
The unit is stuck on radio. The volume control on the unit and steering wheel work and i can navigate the tuner through the steering wheel but not the unit. The buttons are no longer lit when the lights are turned on. all other buttons are non responsive.
Hooked the car up to a PIWIS and the error code PCM MMI 8003 operating button stuck came up.
So two questions really:
1) can this be fixed or is it a brick
2) if it is a brick can i buy a second hand one from Ebay and put it in plug and play? I have read that the unit may need to be coded at an OPC and i will need the VIN of the donor car.
Any advice would be appreciated.
Thanks.
jl-c
PostPosted: Tue Feb 05, 2019 11:43 pm    Post subject: Reply with quote
https://www.revtronic.com/
I have used them to fix the nav system. Very helpfull and know their stuff. You can take the whole car to them if needs be and they will do the job while you wait, but a bit of a trek for you! Give them a call, see what they say.
t1x
PostPosted: Tue Feb 05, 2019 11:48 pm    Post subject: Reply with quote
Thanks for the prompt reply. Yep Bradford is a bit of a journey. I found a company called Cartronix. Anyone used them?
I have used Maple Audio previously but they are not accepting any units at the moment.
monster
PostPosted: Wed Feb 06, 2019 1:01 am    Post subject: Re: Help - PCM problems 2.1 Reply with quote
t1x wrote:
Hi all,
Thanks.
Can't really give you any pointers as to what could be wrong with yours, but the PCM2.1 is definitely plug and play, so if you buy a second-hand one off Ebay it will work no problem (provided its a good one).
It is only from the PCM3 onwards that coding is required incorporating the VIN.
Robert SausageTrousers
PostPosted: Wed Feb 06, 2019 7:53 am    Post subject: Reply with quote
If you do need to buy a second hand one, I still have the one I removed from my car and it's in perfect working condition.
t1x
PostPosted: Wed Feb 06, 2019 1:09 pm    Post subject: Reply with quote
PM sent Robert.
Thanks.
So it's good to know it should be plug and play.
Will it need any re config using a PIWIS?
PostPosted: Wed Feb 06, 2019 1:23 pm    Post subject: Reply with quote
Sounds like Robert may have sorted you out but if not then I also suggest you send the unit to revtronics they will get it back to you within a week fixed. Thumb Thumb
PostPosted: Wed Feb 06, 2019 3:39 pm    Post subject: Reply with quote
I think (?!) my car doesn't have Bose, and the stereos are specific - I assume the speaker covers would have Bose written on them if so?
monster
PostPosted: Wed Feb 06, 2019 5:32 pm    Post subject: Reply with quote
No configuring needed, no need to connect to PIWIS, PCM2.1 is totally plug and play.
monster
PostPosted: Wed Feb 06, 2019 5:45 pm    Post subject: Reply with quote
Good point! - the Bose uses the MOST fibre optic system and there are two different PCM's one for Bose and one without, so if your car has Bose you need to source another BOSE unit.
Have you tried dong a reset on your system first, worth a try as its just a matter of pressing a combination of numbers on the key pad if I recall.
Edit: just had a google - if you press keys 1,4,8 simultaneously this will rest the PCM2.1
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Wed Feb 06, 2019 6:06 pm    Post subject: Reply with quote
Doesn't Tore work on these units too - he's a site sponsor. Begvill FX or similar.
Here he is:
www.bergvillfx.com
PostPosted: Wed Feb 06, 2019 7:11 pm    Post subject: Reply with quote
The fault code would indicate to me .. exactly what it says .. one of the buttons has stuck so the unit is locked .
Coffee spilt on these will do exactly this .. nasty sticky stuff when it gets inside things like this .
You can strip appart a pcm to get at the front buttons .. its not for the faint hearted but not exactly hard either ..
Ive changed screens and sim card holders on these before.
As it is .. you dont have much to loose .
jonno_
PostPosted: Wed Feb 06, 2019 9:26 pm    Post subject: Reply with quote
Or a few squirts with electronic contact cleaner?
