996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
VIB12
PostPosted: Tue Feb 05, 2019 3:55 pm    Post subject: Windscreen washer pipework Reply with quote
Question
New porsche owner here and have unfortunately encountered a problem with the windscreen washer pipework breaking at the hinge from the bonnet to the wing hence screen wash spraying out sidewards between the wing and bonnet!
Car is a 991 cabrio, any ideas if this is a common fault and can be easily fixed or do i have to return the car to Porsche to get ripped!
Thanks in advance and apologies if this is already a thread but i am unable to locate it!
PostPosted: Tue Feb 05, 2019 7:09 pm    Post subject: Reply with quote
Common to a degree , ive seen mice chew through it and some just break .
Its kinda fiddly from what i remember the last time i did one .. you have to get the top part from Porsche but there is a join a bit down under the panels in that corner .. thats the hard bit , getting the old out and the new one in .
Its not been mentioned before in the 991 section that im aware of .
EDIT ..
If your not happy doing it then get a local Indy to replace it for you , hell of a lot cheaper than an OPC .
PostPosted: Tue Feb 05, 2019 11:58 pm    Post subject: Reply with quote
Welcome
VIB12
PostPosted: Wed Feb 06, 2019 9:43 am    Post subject: Reply with quote
Thanks DeMort for the advice, i will get on to Porsche and also look for an indy in Kent, Any ideas???
PostPosted: Wed Feb 06, 2019 7:01 pm    Post subject: Reply with quote
The only 2 i know are Paragon and Prescion Porsche but not really Kent area .
PostPosted: Wed Feb 06, 2019 7:10 pm    Post subject: Reply with quote
VIB12 wrote:
...... and also look for an indy in Kent, Any ideas???
I can recommend 'Project 9' in Marden.
VIB12
PostPosted: Wed Feb 06, 2019 7:12 pm    Post subject: Reply with quote
Thank you, i will give them a call thumbsup
6appeal
PostPosted: Wed Feb 06, 2019 9:24 pm    Post subject: Reply with quote
I had mine replaced under warranty by the OPC, did it whilst i waited, hardly took a moment to be replaced so i can't imagine its an expensive repair... 30 mins tops!
Present:
991.2 Carrera, SC, PDK, Toys Smile
Yamaha MT01
VW T2 Bay Window 1976
Past:
640d GC, 635d Coupe, RS6 C5, Audi TT 225 Coupe, Astra with wind up windows, Citroen ZX, Rover 213, yes behold, a Rover 213... Renault 5
