997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
Midniteblue993
PostPosted: Tue Feb 05, 2019 2:18 pm    Post subject: 1994 993 rear springs rate (color code) Reply with quote
Hello, anyone know which standard rear coil springs (violet color marking or Grey color marking) for 1994 993 Carrera 2 without air conditioning.
I found 2 type of springs but didn’t know which one I should go for. My original springs are so rusty now that cannot tell my color code.
Thanks all for your help.
Windy101
PostPosted: Tue Feb 05, 2019 4:50 pm    Post subject: Reply with quote
Have a look here
http://www.911uk.com/viewtopic.php?p=579999
Windy101
PostPosted: Tue Feb 05, 2019 5:48 pm    Post subject: Reply with quote
Windy101 wrote:
Have a look here
Reading this more carefully it maybe does not answer your question. A call or mail to these guys would almost certainly clear up any confusion. Let us know if you find out anything useful.
http://www.centregravity.co.uk/
wozy
PostPosted: Mon Feb 11, 2019 9:13 am    Post subject: Reply with quote
I’ve been informed that the springs are then same for both air and non air con cars.
Ringing your local OPC will give you the answer or call Matthew at Type911 who I purchased mine from.
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
decgraham
PostPosted: Mon Feb 11, 2019 12:08 pm    Post subject: Reply with quote
Just removed my 4 wheels to send off for a refurb so easy to get to the springs. I have attached pics of the front (Red) springs and rear (Grey) springs. My car is a 1995 C2 Cab Tip S and does have A/C but by what wozy says this should not be an issue.
ATB Smile
 Filesize:  95.77 KB
 Viewed:  913 Time(s)
 Filesize:  101.04 KB
 Viewed:  913 Time(s)
rogttr
PostPosted: Mon Feb 11, 2019 2:38 pm    Post subject: Reply with quote
See my post timed at 1259 on page 2 of this thread.
http://911uk.com/viewtopic.php?t=60605&postdays=0&postorder=asc&start=20
Chris at CG will be able to give you chapter and verse if in any doubt.
C2S Arena Red.
