997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
jaw62
PostPosted: Mon Feb 04, 2019 7:48 pm    Post subject: 20mm rear wheel spacers Reply with quote
any comments on 20mm rear wheel spacers, 997.2 C2 S
might they damage the wheel arch.
997.2 C2 S PDK
ex 993 1995 Targa Tip
ex 964 1989 C2 manual
FZP
Paul Ricard
PostPosted: Mon Feb 04, 2019 8:17 pm    Post subject: Reply with quote
It all depends on the wheel offsets you're going to use it with. Frpm memory 15mm are the go to size with std 2S wheels
ayton1
PostPosted: Tue Feb 05, 2019 6:32 pm    Post subject: Reply with quote
15mm on my 2S with std wheels & 295 tyres brings them right out flush with the edge of the arch, Any more & they would stick outside the arch.
Tobyone
PostPosted: Tue Feb 05, 2019 6:44 pm    Post subject: Re: 20mm rear wheel spacers Reply with quote
20mm may be a bit much.
Try them and if they are to fat send them to me and I will thin them down for you. Free just pay the post.
There you go you cant say fairer than that.
Just pm me. Just spreading the love Very Happy
997.1 C4s GT Silver, factory Aerokit
CarreraMonkey
Watkins Glen
2007 Porsche 997 Carrera 4S
PostPosted: Wed Feb 06, 2019 4:01 pm    Post subject: Reply with quote
I'd be tempted to try the old washer stack trick to see how far out the wheel gets pushed before buying.
Essentially use washers behind the wheel on 3 bolt locations to act as a spacer. Be sure to put the car on the deck and roll it back and forth a bit to get the ride height back, then see how the wheel and tyre sit.
I couldn't even go to 15mm with mine as the tyres with their rims saver edges stuck out and it looked crap. Perhaps if I was another 15mm lower it would have worked, but at -25mm it looked stupid. So I ended up with 5 and 12 rather than 7 and 15 mm spacers which is the norm by all accounts.
Laters Taters!
RXP.
PostPosted: Wed Feb 06, 2019 4:06 pm    Post subject: Reply with quote
Also consider how Camber too.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Wed Feb 06, 2019 4:28 pm    Post subject: Reply with quote
Just in case - don't forget you'll need longer wheel bolts to run spacers.
DucatiRob
PostPosted: Wed Feb 06, 2019 8:07 pm    Post subject: Reply with quote
I'm running 15mm spacers at the rear with Oz Legerra wheels that have a +2mm greater offset, so 17mm combined, I have just lowered with Ohlins shocks by around 20mm, I reckon you couldn't go much more than this without running into problems. Also, the wider track/stance only looks right once the care is lowered, if not then in my opinion it just accentuates the gap between the wheels and the arch!
Before lowering
Mercedes CLK DD
Ducati 996
FZP
Paul Ricard
PostPosted: Wed Feb 06, 2019 9:03 pm    Post subject: Reply with quote
Where's the after pic Dont know
DucatiRob
PostPosted: Wed Feb 06, 2019 9:19 pm    Post subject: Reply with quote
Embarassed Haven't had chance to take any pics from a similar angle yet! The only one I have:
Mercedes CLK DD
Ducati 996
jonno_
PostPosted: Fri Feb 08, 2019 5:54 pm    Post subject: Reply with quote
Before lowering
Rob - is that a turbo spoiler in that pic or just an add effect?
DucatiRob
PostPosted: Fri Feb 08, 2019 9:46 pm    Post subject: Reply with quote
jonno_ wrote:
Before lowering
Yes it is Jonno, it is no longer on the car though! I had a modified Agency Power twin cone filter intake fitted as you can't use the standard airbox with the turbo wing. I just couldn't get the engine to run properly though so I ended up removing it after having he engine rebuilt. Keep thinking about refitting with a different airbox solution, but not so sure I will.
Mercedes CLK DD
Ducati 996
