997 : 2004- 65
Macan : 2014- 6
Harvster
PostPosted: Sun Feb 03, 2019 9:15 pm    Post subject: Help With 996 Centre Console? Reply with quote
Hi everyone,
I wondered if anybody could help. I am wanting to move the air conditioning controls up a level in the centre console, and replace the cd storage.
I will therefore need a new surround trim, rectangle (as the current one is tapered).
Does anybody know the part number for this trim or better still, have one they don’t need anymore.
The whole project is changing the area where the air conditioning controls is to a shelf area (I already have this part)
Thank you!
Porsche 911 996 4S 2003
 Filesize:  488.52 KB
 Viewed:  877 Time(s)
PostPosted: Sun Feb 03, 2019 10:28 pm    Post subject: Reply with quote
Like this:
http://911uk.com/viewtopic.php?t=125168
Wink
Paynewright
PostPosted: Sun Feb 03, 2019 10:37 pm    Post subject: Reply with quote
This is mine. Seems alot of work to move everything around if a cubby hole available for above the climate controls....
 Filesize:  1.95 MB
 Viewed:  823 Time(s)
PostPosted: Sun Feb 03, 2019 10:57 pm    Post subject: Reply with quote
The trouble is when your gear lever is constantly in the way of your HVAC. Hence putting it in the higher position.
Harvster
PostPosted: Mon Feb 04, 2019 9:21 am    Post subject: Reply with quote
Alex is exactly right, why Porsche put the A/C controls at the bottom I do not know, that was the main reason behind doing this...
However after reading your DIY thread, I have to concede that I do not have the expertise to attempt it, I didn't realise it would be that involved Surprised Sad
Oh well.
PostPosted: Mon Feb 04, 2019 9:27 am    Post subject: Reply with quote
I did got a bit OTT with the method as I had no work on at the time and have the 'tools'. Job could easily be done with a Stanley knife, hacksaw blade and a file. Someone on here I think did it a while ago if you have a search.
