991 : 2011- 19
993 : 1993-1998 7
Cayenne : 2003- 4
emohawk11
PostPosted: Thu Jan 31, 2019 11:33 am    Post subject: No sound \ music from Radio, CD or phone bluetooth pairing Reply with quote
Hello,
The head unti is powered on, and shows all the radio stations etc. However there's no sound anymore. I've obviously checked the sound is not muted. I;ve tried a cd, bluetooth with phone and music. no sound at all from any source.
The only sound I can get out of the speakers is while making a telephone call.
Only other observation is the head unit powered off and back on again whilst driving the day before this happened. There was sound though until this morning.
Can someone suggest what I need to check please?
emohawk11
PostPosted: Thu Jan 31, 2019 12:54 pm    Post subject: Reply with quote
Update - sound has magically returned. The car was left sat for about an hour.
Any thoughts ?
PostPosted: Thu Jan 31, 2019 8:02 pm    Post subject: Reply with quote
With computers and im afraid the PCM is a computer these days then you get software glitches ..
One fix is to lock the car and wait 10 mins or more .. this effectively shuts down the computer ..
If your PC at home stops working you turn it off then back on .. same thing here but it takes a little longer .
Ive often had to do this when replacing control units or retro fitting items .. ive often fixed faults just by unplugging the connections and plugging them back in whilst testing things .. infuriateing to be trying to find a fault only for it to have it to fix itself , you have no idea if it will come back or if its job done .
Its a case of monitor it for now .. an actual fault will return , software and its only now and then .
rob_p
PostPosted: Thu Jan 31, 2019 8:54 pm    Post subject: Reply with quote
I had something similar happen pre Xmas. No sound from head unit in the morning. When I used again in the afternoon it worked fine.
Gremlins...
991.1 C2 (no mods, yet)
Jeep Grand Cherokee WK2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
emohawk11
PostPosted: Fri Feb 01, 2019 8:21 am    Post subject: Reply with quote
thanks both
