997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Danbassy
PostPosted: Wed Jan 30, 2019 9:02 pm    Post subject: PCM 3.1 system version 2.20 Reply with quote
Would it be possible to update my pcm firmware if I borrowed a map cd on a newer model from a friend?[/i]
PostPosted: Wed Jan 30, 2019 9:33 pm    Post subject: Reply with quote
Difficult to answer .. if i was doing a nav map update then i would have to bring the software of the individual components up to date first .. i would then load the nav update .
Up dateing the software on its own is more for error correction .. it has no real benifit .. if it works then it works .. but a nav update is the newer maps and hence needs the basic software to be upto date .
Map update cd and software update cd,s are different items which need to be loaded .. i can say .. its a pain and is fraught with problems although to be fair for some reason the sports cars seem to be harder than Cayennes .
Personnelly i think a Tom Tom is far cheaper .
Indy Mechanic .
Danbassy
PostPosted: Wed Jan 30, 2019 9:52 pm    Post subject: Reply with quote
Appreciate the response, just seems my firmware is way behind. Are you saying there isn’t much point in updates to 4.xx?
PostPosted: Wed Jan 30, 2019 9:56 pm    Post subject: Reply with quote
If your not updateing things like maps then no .. software update is more bug fix than actual improvement .. may be slight but nothing of real value
Indy Mechanic .
