997 : 2004- 74
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
PanozGTR
PostPosted: Wed Jan 30, 2019 10:56 am    Post subject: Porsche warranty claims Reply with quote
Has anybody had their shock absorbers replace on the Porsche extended warranty. I notice that they are on the exclusion list. Is it worth trying my luck with a claim as my dampers are showing some signs of leaking.
2009 997.2 C2S Macadamia/Cocoa
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
PostPosted: Wed Jan 30, 2019 12:34 pm    Post subject: Reply with quote
On a 10 year old car ........ Dont know .......... but I wouldn't hold my breath.
Good luck, please let us know what they say.
What mileage has the car done. Question
Windy101
PostPosted: Wed Jan 30, 2019 4:54 pm    Post subject: Reply with quote
My GT3 had new struts while under warranty and the warranty did not cover them.
PanozGTR
PostPosted: Wed Jan 30, 2019 5:04 pm    Post subject: Reply with quote
That's my problem l think l'll pass out first as it has covered 80k miles. Just checking to see if it's worth trying to claim. Surprised
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
Windy101
PostPosted: Thu Jan 31, 2019 10:31 am    Post subject: Reply with quote
I would say almost certainly not.
grbspeedster
PostPosted: Thu Jan 31, 2019 11:17 am    Post subject: Reply with quote
I would assume most 'wear' items are excluded. Brakes, shocks,clutch etc . Never seen them included in any warranty I've had
Geoff
996 X50 turbo cab
PanozGTR
PostPosted: Thu Jan 31, 2019 6:36 pm    Post subject: Reply with quote
I guess a quick phone call should let me know. I'll let you know the outcome.
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
Axlesnap
PostPosted: Thu Jan 31, 2019 7:05 pm    Post subject: Reply with quote
The warranty did cough up for front shocks on my C2S but the issue was traced to the PSAM function and deemed to be a failure rather than wear and tear. Good luck but I suspect it won’t be covered.
997.2 GT3
TonyC911
PostPosted: Fri Feb 01, 2019 7:57 pm    Post subject: Reply with quote
Pop Corn
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
PostPosted: Fri Feb 01, 2019 8:08 pm    Post subject: Reply with quote
Its always worth claiming .. its worth argueing .. its worth talking to customer services At Porsche ..
Do i think you will get anywere .. nope .. but if you dont try then you have no chance .
At best you might get 10% customer good will .. but again i doubt it .. if no joy .. use an indy .. cheaper labour rates .
PanozGTR
PostPosted: Mon Feb 04, 2019 10:18 am    Post subject: Reply with quote
I have booked the car into OPC Mid Sussex on Wednesday. I am expecting a big fat nothing from them, but l am just interested in what they have to say. I have just recently had my C2s serviced at PRECISION PORSCHE in Sussex and will be letting them look after my pride and joy in the future. I found them to be absolutely spot on. They were very meticulous and obviously know their stuff. I was treated like a person rather than a wallet coming through the main dealer door.
I'll keep you posted on the outcome at OPC Mid Sussex
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
PanozGTR
PostPosted: Wed Feb 06, 2019 3:37 pm    Post subject: Reply with quote
So I visited OPC Mid Sussex today to check out my car. The result was better than I had expected. The Dampers are not covered but on closer inspection they don't look bad at all , just a slight misting around the upper part. They couldn't find the leaky hose hmmm! so I'll have to keep an eye on that. But they did fix the headlight adjusters under warranty so that was a result at least.
Just for info the headlights were not self aligning up and down. They found nothing wrong physically so they unplugged and reconnected the connectors and they started to work again. (the old engineer's reset)
Happy days Thumb
So there is a small pat on the back for the OPC
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
fastlowe
PostPosted: Wed Feb 06, 2019 3:49 pm    Post subject: Reply with quote
Always interesting what's covered, I was told the front coolant pipes on my 997.2 are showing a few tell tale marks on my last service but they're only covered if they are dripping. They want a grand to sort them !
997.1
944 Turbo
PostPosted: Wed Feb 06, 2019 8:27 pm    Post subject: Reply with quote
Happy days Thumb
Just to be the usual cynical person that i am .. .. one of those plugs had corrosion on a terminal , unplugging it has in effect cleaned the terminal to make a better connection.
There is no software involved in that operation .
On the plus side .. it works Thumb
PanozGTR
PostPosted: Thu Feb 07, 2019 11:28 am    Post subject: Reply with quote
Demort. That was my thinking as well Thumb
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
PostPosted: Thu Feb 07, 2019 8:48 pm    Post subject: Reply with quote
If not leaking then bury them in waxoil or acf 50 .. these are common im afraid and its due to water ingress that causes corrosion to the metal part of the rubber pipe .
@ PanozGTR
Slight misting of shocks wont be covered by a warrenty but its an advise that they have a small fault.. obviously it wont get better so the garage is warning you you have a possible future problem .. we report what we see Smile
Last point .. if useing Mid-Sussex .. ask for Matt or Jason to work on your car .. both good guys .
PanozGTR
PostPosted: Thu Feb 07, 2019 9:03 pm    Post subject: Reply with quote
Thanks for the Advice deMort. I shall be getting any work done at Precision Porsche in Sussex in future. Luckily they are only a couple of miles from where I live. As I mentioned earlier they are a very professional outfit and I get the feeling that they will look after my car better than the main dealer.
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
